    are 1st and second gen 10 bolt axels the same
    Number of posts : 1383
    are 1st and second gen 10 bolt axels the same Empty are 1st and second gen 10 bolt axels the same
    Post by BILLS66 Thu Jul 15, 2010 5:13 pm
    Going to strip the rearend out of the 70 parts van and just wondered if the axels were
    interchangable with a 1st gen? Bill
    Number of posts : 801
    are 1st and second gen 10 bolt axels the same Empty Re: are 1st and second gen 10 bolt axels the same
    Post by panelmanrd Thu Jul 15, 2010 5:48 pm
    i think they are the same with axle flange to axle flange,
    but the spacing of the spring saddles are different, one
    is about 1/4 inch different, i think due to the difference
    of the spring widths. i just can`t remember whitch one
    is wider.
    Post by BILLS66 Thu Jul 15, 2010 6:03 pm
    I was just thinking if the axels were good I would save them for future use just in case I needed them down the road. Bill
    Post by panelmanrd Thu Jul 15, 2010 7:28 pm
    if they are both 10 bolt or both 12 bolt the internals, including
    axles are interchangable. i think it would be a smart thing
    to hang on to.
    Number of posts : 7900
    Post by DanTheVanMan Thu Jul 15, 2010 8:32 pm
    Bill,
    I'm hanging on to mine from the 69 as well. Just to be on the safe side....
    I seem to remember that you can put a 2nd Gen. into a 1st but not the other way around...
    Dan
    are 1st and second gen 10 bolt axels the same Qr_cod10
    Post by donivan65 Fri Jul 16, 2010 12:33 pm
    When the 1st and 2nd Gen rear ends are next to each other, I don't see any difference,,,,,,,now the axles change depending on the rear end gear ratio,,,,,,,,and the 31 1/2" long , 1 3/16" diameter, 28 spline, 10 bolt rear axles are REALLY something to hang onto,,,,,,,they are fading out fast,,,,,,,
    Post by BILLS66 Fri Jul 16, 2010 12:57 pm
    Thanks guys the rear has 3.36 gears like my van and rather than keep the rear end laying around I would just strip it and save the insides. Bill
      Current date/time is Sun May 19, 2024 6:16 am
