+5
Hamilton
9 posters
    a place for the battery (1970 A100)
    Hamilton
    Hamilton
    Number of posts : 95
    Registration date : 2010-07-06
    a place for the battery (1970 A100) Empty a place for the battery (1970 A100)
    Post by Hamilton Tue Jul 06, 2010 7:07 pm
    the battery is literally simply sitting behind the drivers seat on the floor. Is there a carriage, or box or something that can be purchased to house this battery? Is this normally where they position in these vans? seems like it should be attached to floor somehow...
    a place for the battery (1970 A100) Batteryposition
    thanks for the advice!
    hami
    a place for the battery (1970 A100) Empty Re: a place for the battery (1970 A100)
    Post by G-Man Tue Jul 06, 2010 7:19 pm
    It should be in a box there
    Hamilton
    Hamilton
    Post by Hamilton Tue Jul 06, 2010 7:23 pm
    cool Gman, is that an item I could get at say, Autozone? Or more of a specialty item I'd find on line? thanks!
    Post by Digz Tue Jul 06, 2010 7:33 pm
    I wouldn't be suprised if one of the guys here has a good one available and a good pic of it. I've got 1 but the condition is questionable, the bottoms get corroded sometimes, I would think about a marine type battery box to get you by for now if one doesnt turn up right away. I can double check the one I have if need be. Also depending on what you might want to do , it looks like the slide out step is missing on your van? ( the step is the reason for sticking the battery behind the seat). you may be able to do an under floor mount near the side doors with a little slice and dice and some donor parts.
    Post by G-Man Tue Jul 06, 2010 8:41 pm
    If you do fine a stock one in good shape have it powder coat so it won't corrode as easily.
    Number of posts : 3046
    Post by RodStRace Tue Jul 06, 2010 9:10 pm
    Originals have a top and a bottom, both metal. There are 2 holes at the bottom inside, with grommets for the cables. There is also a wedge shaped cover for the cables that is screwed down. 2 more holes with grommets for the cables in the floor, next to the doghouse.
    Unless you are a stickler for detail, a marine or race car battery box would be fine. Just make sure to protect the cables (grommets) and vent the battery to the outside.
    Post by donivan65 Tue Jul 06, 2010 9:22 pm
    Well,,,,,,I surely would not like smelling the corrosion and acid coming out of that battery,,,,,,I would be getting something like this Chevy Van battery box or even building something out of angle iron or steel staps and mounting it under the van under the floor. You could make an access door in the floor but you don't really need one to get by,,,,,,,
    a place for the battery (1970 A100) Workin15
    Hamilton
    Hamilton
    Post by Hamilton Wed Jul 07, 2010 3:38 am
    cool, good advice fellas! thanks tons, gonna do some snooping around and see what I can find....thanks!!!
    Number of posts : 1605
    Post by itruns Sat Aug 21, 2010 6:20 am
    http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=102091&catalogId=10001&langId=-1&storeId=11151&storeNum=10109&subdeptNum=10548&classNum=10551
    Be sure to fasten it to down and use the tie strap. If the van rolls, you don't want the battery hitting you in the head Shocked Something like that could make a bad day even worse...
    Hamilton
    Hamilton
    Post by Hamilton Sat Aug 21, 2010 11:25 am
    excellent point, itruns. I went to walmart, bought the $7 marine battery box. Drilled holes in it and the floors, ran some nice long bolts thru it, lock nuts and washers, strapped it down!
    a place for the battery (1970 A100) Batterybox
    BajaCharlie
    BajaCharlie
    Number of posts : 619
    Registration date : 2010-01-07
    Post by BajaCharlie Sat Aug 21, 2010 5:48 pm
    that is the stock location for the battery in all A100's heres a pic of one of mine. note the metal cover for the cablesa place for the battery (1970 A100) 00610a place for the battery (1970 A100) 00710
    Hamilton
    Hamilton
    Post by Hamilton Sun Aug 22, 2010 5:04 am
    that's way cool Baja!
    BajaCharlie
    BajaCharlie
    Post by BajaCharlie Sun Aug 22, 2010 9:47 pm
    the box and the cable cover are stock parts you can find um around mostly ebay
    Number of posts : 7900
    Post by DanTheVanMan Mon Aug 23, 2010 5:55 am
    a place for the battery (1970 A100) Qr_cod10
    BajaCharlie
    BajaCharlie
    Post by BajaCharlie Tue Aug 24, 2010 1:21 am
    yeah I gotta say that Chevy had the coolest idea for battery location.I have a really nice Chevy battery box lid if ya go that route.
    69 a 100
    69 a 100
    Number of posts : 142
    Registration date : 2009-01-03
    Post by 69 a 100 Sun Aug 29, 2010 7:45 pm
    i remounted mine in the back of the van behind the right rear wheel well, but i also put in a kill switch outside the van
      Current date/time is Wed May 01, 2024 10:00 pm
