I NEED TO FIND THE THROTTLE CABLE FROM BEHIND THE GAS PEDEL @ THE BELL CRANK TO THE 600 CFM EDELBROCK CARB ON A 318 WITH A 727 CAN ANY ONE POINT ME IN THE RIGHT DIRECTION AS TO WHAT TO USE ?? I HAD A /6 SO I HAVE NOTHING THAT WILL WORK AT THIS TIME... THANKS IN ADVANCE GUYS!!!!!!!!
THROTTLE CABLE
- Number of posts : 8729
THROTTLE CABLE
kltcustoms- Number of posts : 199
Registration date : 2008-07-07
Re: THROTTLE CABLE
Not sure if this helps but I used a VW style cable and then bent a large hardline fuel line and ran the cable thru is to keep it stable...ran it the same route the original rod went thru. Drilled and attached clamps for the hardline to keep in place then added return springs. Worked well but mine is in a 225 super 6 so......hope this helps.
Kent Talley
Kent Talley
Re: THROTTLE CABLE
Here is the part number I have from Nate. I'm still using linkage, so no idea on how this will work.
http://www.jegs.com/i/Trans%20Dapt/969/4131/10002/-1?CT=999&sendroicid=bbef8492-2d00-41d6-b158-38db0de2603c&sendroiad=1664068059&sendroikwd=Trans+Dapt+4131&gclid=COLF47L00KICFQQMDQod3icjxw
Re: THROTTLE CABLE
