ok, here I am again with non stock ideas. I am thinking of mounting the v-8, near to the back. eliminating the stock doghouse and installing, a bench front seat...anybody done it.? ideas.? thanks
rockin rebel
1st series, v-8 in the back.??
rockin rebel- Number of posts : 24
Registration date : 2009-11-26
Re: 1st series, v-8 in the back.??
I bet there isn't one of us who hasn't thought about moving the engine back. My thought would be doing it with an IRS set-up. You can can stick a large radiator with electric fans almost anywhere. I remember seeing it done in a van mag years ago. Maybe somebody has a lead on it. but you would only gain about 18 inches and still have a drive shaft hook up. Im curious if there are any other thoughts on this?
I really would like to see this on a driver, I've seen it on the strip, but never on something that street driven. The corvair vans with there bench seats have so much room up there
well I guess I better start measuring...lol...If I pull this off, I will take tons of pics...also want my van, on the ground too...ideas...
G-Force- Number of posts : 56
Registration date : 2010-04-02
Large front bumper. Maybe a brush guard. And oh yeah, Lots of cheese burgers and milkshakes!
How about using a Toronado or Eldorado trans axle? That would give you rear IRS and then do a Mustang II setup in the front, it would be easy to slam that way.
oo3- Number of posts : 290
drive shaft is not to long so moving a normal type engine back wont do to much - i think i recall someone either did or discussed a front wheel drive set up like a cad northstar transverse set up in the rear (like fiero mod) - maybe it was over at vcvc - that would mean some sort of hump in the back i would guess - oo3
Scott- Number of posts : 1651
Could you use the front axle from a 4x4 and just not use the rear axle?
Then you could move the engine way back with a long driveshaft. Could turn the engine around too.
