does anyone sell a kit with the correct motor mounts for a slant 6 to small block swap.i am going to swap the guts from my slant six 727 to my v8 trans so i can reuse the short tailshaft so i need motor mount info? thanx dave
v8 install parts?
cochise1304- Number of posts : 4
Registration date : 2008-11-24
v8 install parts?
Re: v8 install parts?
no kit I'm aware of...
Where are you? I just pulled a set of V8 body brackets off today.
i am in portland oregon
- Number of posts : 8729
YOU ONLY NEED THE BRACKET FROM THE DRIVERS SIDE. AFTER THAT YOU NEED A BOAT LOAD OF SMALL THINGS
YES YOU DO NEED MOTOR MOUNTS
Henrik- Number of posts : 156
i'm not sure if this is what you are looking for but. these guys could know where to get the right brackets.
http://www.engine-swaps.com/Pages/ProductsType/EngConvKits.html#head8
Before you swap the guts check the bell housing, some of the early 727's had a 1" cast spacer to adapt them to a /6. There are plenty of engine brackets here on the site, the V8 radiator necks are opposite so you need a radiator or a good shop. All the rest of the stuff is easy at a parts house for a 273/318. What small block are you going to use???
rubber motor mounts autozone A2338 14.99 x 2
» Parts,parts,& more parts=dodge, econo & chev stuff
» Sheet metal parts This buisness sells many different metal replacement parts for older cars trucks!! I know i have seen some van parts for our vans here from him!1 If it isnt listed - email or call them!!
» newbie, parts and parts pics and part locations
» Brake light switch
» some will cry -some will laugh- just costs $$ to fix!! & parts is =Parts!
