    how to take off emblems
    how to take off emblems Empty how to take off emblems
    Post by Guest Wed Apr 14, 2010 9:45 am
    trying to take off the emblems out of the doors and the front
    was doing it late last night but stopped and decided to ask first
    before i break any of them..thanks
    Number of posts : 1148
    how to take off emblems Empty Re: how to take off emblems
    Post by jkr Wed Apr 14, 2010 2:44 pm
    theres metal inserts into the holes in the doors and front panel the letters push into. the pins are brittle and do break but try some penetrating fluid on the pins and slowly pry from the body with a flat metal scraper evenly. the single letters have 2 pins and the door script has 3. don't worry to much cause you can always use a good 2 sided tape to reinstall them. i used both tape and the inserts and they dont move or rattle which saves paint chips and rusting.
    Number of posts : 3046
    Post by RodStRace Wed Apr 14, 2010 3:03 pm
    If you are really concerned with the pins, after soaking try carefully pushing STRAIGHT OUT on the pins from behind.
    The front ones are tough to access unless the heater is out.
    Here is a picture, looking from the passenger side toward the driver's side under the dash showing the pins and the little clips that hold them.
    how to take off emblems Frontemblandwiring
    Number of posts : 2067
    Post by sasktrini Wed Apr 14, 2010 3:47 pm
    You can see that on an A? I thought they were blind inside the heater cavity! COOL!
    Post by Digz Wed Apr 14, 2010 5:20 pm
    On my 66 A parts van the door script has those sheet metal speed nuts on the back.
      Current date/time is Wed May 08, 2024 6:04 am
