wbulick76
    Another header question....
    wbulick76
    wbulick76
    Number of posts : 17
    Registration date : 2010-03-25
    Another header question.... Empty Another header question....
    Post by wbulick76 Sat Apr 03, 2010 6:10 am
    Hey guys,
    I did a search but didn't find what I was looking for. I just bought a small block motor to go in my 69. the guy I bought it from gave me a set of headers to go with it that came off of his 69 Camaro. Can I use these on my van?
    Another header question.... Empty Re: Another header question....
    Post by Guest Sat Apr 03, 2010 7:17 am
    I would "test" fit them. The problem with using headers from other applications seems to be clearance. If the dont hang down to far to be an issue, then use them.
    Post by G-Man Sat Apr 03, 2010 11:18 am
    Most of the time they messes with linkage and over heats the starter, save some time and go with block hugger headers
    Number of posts : 1383
    Post by BILLS66 Sat Apr 03, 2010 1:20 pm
    Block huggers are the answer. Bill
    Post by Digz Sat Apr 03, 2010 5:42 pm
    I'm running long tube headers that were for a 3rd gen van, but I'm all cable controls so linkage isnt an issue, but like the guys say, the block huggers should solve a lot of potential problems and I'll be going that way when I get these worn out. But it cant hurt to at least try "free" headers.
    wbulick76
    wbulick76
    Post by wbulick76 Sat Apr 03, 2010 5:51 pm
    That's what I figured when the guy offered to throw them in! The big Charlotte Auto Fair is next weekend, so I may just grab a set of block huggers and be safe.
    Post by G-Man Sat Apr 03, 2010 6:53 pm
    Go the extra mile and get ceramic ones
    Post by BILLS66 Sat Apr 03, 2010 8:23 pm
    for the long haul go ceramic they produce alot less heat. Bill
    HOTRODVAN
    HOTRODVAN
    Number of posts : 97
    Registration date : 2010-10-01
    Post by HOTRODVAN Thu Jan 27, 2011 4:49 pm
    Why not just sell the free ones and put that money towards the ceramic block huggers Very Happy
    I have a set of long ones (not sure what they were actually for) on my '64 no-door. I think they hang down too low. I will be putting on the ceramic block huggers mainly for heat and they'll tuck up under the van better.
    Post by Guest Sun Jan 30, 2011 11:03 pm
    center dump ram horns with 2 1/2 dump, cant go wrong with them.
    Number of posts : 822
    Registration date : 2010-09-10
    Post by Roman Mon Jan 31, 2011 3:59 pm
    bowtie56jw wrote:center dump ram horns with 2 1/2 dump, cant go wrong with them.
    You're 100% right! They are perfect for a stock to mild performance engine. If you're running ported heads and making big power you'll need headers. I have the Speedway Motors cast S/S Tru-Ram manifolds on my Cadi 385 HP/405 FT LBS. Perfect performance, but they had to be ported to match the D port heads and I had to cut off the left flange and weld a tube to suck it in away from the steering box.[img]Another header question.... Imag0110[/img]
    Post by Roman Mon Jan 31, 2011 4:02 pm
    For a van they would go in like a $2 ho as long as your heads have round exhaust ports.
      Current date/time is Sun May 12, 2024 2:54 am
