    Fuel Tank Sending Unit
    southern man
    southern man
    Number of posts : 486
    Fuel Tank Sending Unit Empty Fuel Tank Sending Unit
    Post by southern man Tue Mar 30, 2010 5:04 pm
    My gas guage doesn't work and we're getting no signal from the fuel tank sending unit. I'm guessing it needs to be replaced but as most of you know it requires the removal of the tank. Before I do that:
    A. Do you think my analysis is correct?
    B. I did a quick search for the part, and came up with this link:
    http://www.thepartsbin.com/catalog/?N=4294967069&Nr=OR(AND(make:Ford,model:Econoline,year:1964),AND(universal:1))&Vi=1616+10416+4294962392&y=1964&mk=Ford&md=Econoline
    Does this look like a direct replacement, or does anyone know what might be a better choice?
    Thanks!
    Jeff
    Number of posts : 466
    Fuel Tank Sending Unit Empty Re: Fuel Tank Sending Unit
    Post by Sy Hollinshead Tue Mar 30, 2010 11:23 pm
    Your link doesn't work, but i think you mean these....
    http://www.thepartsbin.com/catalog/?N=4294967069&Nr=OR%28AND%28make:Ford,model:Econoline,year:1964%29,AND%28universal:1%29%29&Vi=10416+4294962392+1616&y=1964&mk=Ford&md=Econoline
    They look like standard universal ones to me. You may get lucky and find out they fit. I asked a question on here about a year ago, and somebody found me one of something else that should fit.
    Post by donivan65 Wed Mar 31, 2010 8:23 am
    I like that price,,,,,but those are held on by screws and use a smaller hole. BUT by taking off the resistance unit and mounting it on your old pick up tube, you could make it work like on this Chevy one.
    Fuel Tank Sending Unit Repai118
    Fuel Tank Sending Unit Repai119
    southern man
    southern man
    Post by southern man Wed Mar 31, 2010 9:58 am
    Thanks guys (don't know why my link screwed up, but Sy you certainly found it).
    Post by donivan65 Wed Mar 31, 2010 10:54 am
    I would see if there is a ground wire from the top of the fuel sender to the frame. Then disconnect the sender wire at the tank or at the next closest connector and briefly ground the wire going up to the gauge,,,,,,it should make the gauge go FULL,,,,,the gauge should read EMPTY if the wire is disconnected.
    primaldesigns
    primaldesigns
    Number of posts : 71
    Registration date : 2009-01-11
    Post by primaldesigns Wed Mar 31, 2010 3:41 pm
    Hey Southern,
    Did you test your fuel gauge first? You can test it with a simple flashlight battery. I had to replace my fuel sending unit. I found one online that was an exact replacement for the stock unit and it works great. Here is the link to the replacement fuel sending unit.
    https://secure435.hostgator.com/~dlvry40/ufolder/ShowProducts.php?c=3&s=128&g=971&t=4593
    southern man
    southern man
    Post by southern man Wed Mar 31, 2010 4:11 pm
    Thanks primal! A bit pricey but I ordered it. Tired of having no gas guage. Yes, guage works.
    primaldesigns
    primaldesigns
    Post by primaldesigns Wed Mar 31, 2010 5:42 pm
    I know it's a little more than other sending units but I figure that the few extra buck are worth not having to make any modifications and the frustrationthat come with the mods!
    Post by donivan65 Wed Mar 31, 2010 11:32 pm
    $65 ain't pricey to some of us,,,,,,,,
    Fuel Tank Sending Unit You_se10
      Current date/time is Mon May 20, 2024 9:27 am
