Ive rebuilt the entire front end, kingpins, tie rod ends...but the steering box seems loose. I tried adjusting the play in the box but if I go too tight I hear popping and knocking noises when I turn it. Then if I loosen it up it has too much play in it and wanders/drifts when I drive it. I was curious if this is something that can be rebuilt or do I just need to try and find a good used one? Thanks...
Steering box problems?
Re: Steering box problems?
Theres an art to rebuilding them but it can be done or try Straight Line Steering for a rebuild. You definitely dont want to adjust the box too tight. Some play is normal.
Thanks I called them and they want around $530 shipped.... I was hoping for a good used one?
Well, Im picking up a parts van up near Detroit this Sunday matter of fact so I may be able to get you a good used one.
Try this place. They charge $199.00
http://www.prosteering.com/m_ford_truck.htm
vanishingbreed wrote:Try this place. They charge $199.00
I called them and they don't have any in stock...said they might be able to rebuild mine, if it was good enough...Tim did you get that parts van?
Sure did and its got 54000 original miles so I know the box is good. The steering wheel still has very obvious ribs in it which are the first signs of high mileage. If it wasnt for the rust factor this van would be the freakin cats meow. Its loaded with good stuff. Perfect original interior which is going in my 63 van. Lots of other good stuff I ll be offering up though. Im on vacation this week at home so feel free to ask for anything you need. Email me at Econousaparts@fuse.net
rev.chuck- Number of posts : 71
Registration date : 2010-03-08
watch our local CL theres 4 of these vans floating around out there i see the same ones get listed and relisted every month or so
Just got my steering box back and very impressed with their service! This place specializes in rebuilding the 1st gen Econo steering boxes among other things like rack & pinions, gear boxes, etc. They charge $175.00 to $200.00 (depending on the parts it might need) to rebuild our steering boxes and even have them on the shelf for core exchange...
C J Automotive
5909 Firestone Blvd.
South Gate, CA 90280
Tel: (562) 806-6464
Fax: (562) 806-6466
E-mail: powersupply5909@aol.com
C J Automotive
Tel: (562) 806-6464
Fax: (562) 806-6466
