i need newplugs for my back lights on my 64, 3 wire are they available? thanks bill
back lights
back2thewoods- Number of posts : 842
back lights
Re: back lights
Not sure ,but think there the same for the pickups of that year??
Re: back lights
tail-light housing with wire ends
Re: back lights
donovin, oh guru of thy early!! any clue on my back tail light delema??
Re: back lights
I replaced my tailight housings on my 64, I got new ones from Brothers just order from the pickup parts the same years as the first gens. The lens are also the same as the pickup's so a pig tail will be the same. Remember GM loved to re use parts over and over. Also check your local auto parts alot of times they have sections of the store that has alot wiring parts.
Re: back lights
thanks g-man
Re: back lights
what i need is the sockets with some wire attached to splice offf somebodys parts van
Re: back lights
G-man got the right idea,,,,,NEW STUFF,,,,,,the old ones are troublesome,,,,,,bad connections,,,,,,the wire is called a pigtail,,,,,,Napa just might have them,,,,,but if you go to pages 125 to 127 in that online 1960-72 parts catalog at www. truckandcarshop.com, you will see everything you need , including fancy lenses and LED lights,,,,
Re: back lights
Re: back lights
thanks donovan, we'll hit napa for starts
Re: back lights
Well,,,,,,,if you need the spring and contact wires, this would probably work,,,,,,if you need the plastic tabs, they are probably the same as 60-66 pick up tail lights and 55-57 chevy car front marker lights,,,,,and there are a lot of parts places and catalogs for those 2 types of vehicles,,,,,,you just got to sneak up on those parts,,,,,,,
Re: back lights
donovin, picked up parts from napa, miner mods, all systems go!! thanks for your input!!
