    A100 Original Floor Mats
    SnarkyPoet
    SnarkyPoet
    Number of posts : 174
    Registration date : 2009-12-22
    A100 Original Floor Mats Empty A100 Original Floor Mats
    Post by SnarkyPoet Fri Feb 05, 2010 12:50 pm
    In the process of restoring my van, I have found that the original floor mats are just not available. Consequently, I am in the process of reproducing them. After much searching, I have been able to track down the original 'carpet texture' rolled rubber stock. I also have a source for rubber dyes that can be used to reproduce the original colors and styles. My front mat is intact and I'm planning to use that as a template for a new one, but I don't have the original rear mats to use as a guide. Does anyone here know the layout for the rear mats? Was it one piece or was it in sections? My mats were originally brown with gold flecks. What colors did you guys have? If I can get templates put together, I'm going to try to reproduce the originals as closely as possible.
    A100 Original Floor Mats Empty Re: A100 Original Floor Mats
    Post by G-Man Fri Feb 05, 2010 1:32 pm
    Anything that someone takes the time to reproduce helps all of us, maybe do some for the econo and chevy guys too??? (can't get mats for them either)
    SnarkyPoet
    SnarkyPoet
    Post by SnarkyPoet Fri Feb 05, 2010 2:24 pm
    If anyone has pictures or samples of the material, I'll see what I can dig up. The resources are definitely out there if you look hard enough.
    gravesj
    Number of posts : 34
    Registration date : 2009-02-11
    Post by gravesj Fri Feb 05, 2010 2:38 pm
    Awesome I am in for a set!!!
      Current date/time is Sun May 19, 2024 11:46 am
