    s-10 door seals for 1st gen???
    wacko
    wacko
    Number of posts : 423
    s-10 door seals for 1st gen??? Empty s-10 door seals for 1st gen???
    Post by wacko Fri Jan 29, 2010 9:00 am
    Hey Guys,
    I thought I read somewhere on here that s-10 door seals will work on a first gen but I can't find the thread. Is this true? Is there a certain year range that works the best? I am thinking of heading down to the local pick-a-part and nose around.
    s-10 door seals for 1st gen??? Empty Re: s-10 door seals for 1st gen???
    Post by donivan65 Fri Jan 29, 2010 9:19 am
    Well,,,,,,,I use S-10 door weatherstrip for the Doghouse seal,,,,,,
    s-10 door seals for 1st gen??? Wstrip12
    wacko
    wacko
    Post by wacko Fri Jan 29, 2010 9:21 am
    maybe that is what i was thinking
    Post by donivan65 Fri Jan 29, 2010 9:31 am
    HOWEVER,,,,,,,,I took the weatherstrip off a Dodge van and trimmed it down and used it on my doors,,,,,,so maybe grab one if you find a good one, usually the passenger side is better, and trim it to look like what is on your Chevy.
    Post by G-Man Fri Jan 29, 2010 11:32 am
    The S-10 gasket is the cheaper way to go, but it fits on the on the doghouse not the lid like like it came from the factory. check here for a factory style gasket
    http://www.restorationspecialties.com/
    They just started making the right gasket, last year I sent them a sample from a old one I had and they made a die to make to factory one
    sparky
    Number of posts : 195
    Post by sparky Fri Apr 30, 2010 11:01 am
    donivan65 wrote:Well,,,,,,,I use S-10 door weatherstrip for the Doghouse seal,,,,,,
    Does it matter what year S-10 that seal comes from, and do you want to remove the existing seal from the lid?
      Current date/time is Wed May 08, 2024 7:31 am
