    rear view mirror
    rear view mirror Empty rear view mirror
    Post by Guest Thu Jan 28, 2010 2:33 pm
    did our vans come with rear view mirrors?
    jeff
    Number of posts : 1388
    rear view mirror Empty Re: rear view mirror
    Post by wideload Thu Jan 28, 2010 2:43 pm
    Some did and some didn't. I think it depends on the windows in the doors or it could have been and option. I've got 4 second gens and none of them have interior rear view mirrors but two of them are solid panels. The two with windows both had the external west coast mirrors. My two first gens both have windows and both have the interior mirrors.
    Post by Guest Thu Jan 28, 2010 2:53 pm
    i am going to put one in her but if there is an oe floating around i would like to go that way. the po took off the west coast and put on the ford style universals, wish he would have left them alone.
    Post by wideload Thu Jan 28, 2010 3:06 pm
    Maybe someone else will chime in on this. The first gen type show up on e-bay occasionally but I'm not sure what a second gen even looks like. Check with Bills66 or DanTheVanMan they might have one from the vans they are parting out.
    Post by G-Man Thu Jan 28, 2010 3:16 pm
    I had a rear view mirror in my 69, took it out because I didn't like the looks of that mirror (it wasn't that bad just knew there were cooler mirrors out there) It now has a first gen base w/ a olds mirror I picked up at a swap meet
    Post by donivan65 Thu Jan 28, 2010 7:04 pm
    My 65 has one,,,,,
    rear view mirror Repair69
    Number of posts : 1778
    Post by m1dadio Thu Jan 28, 2010 8:46 pm
    Hey done; does your mirror shake when you drive. Mine does at certain speeds and I am wondering if they are suposed to have an extra suport l;ike I have seen on some other vehicles. Right down behind the ball joint on the mirror of my 65 (on the windshiel side) there is a socket. I have seen vehicles with a post at that place going to a small suction cup on the windshield. Comment?
    M1D
    Post by donivan65 Thu Jan 28, 2010 9:43 pm
    Well Michel, my mirror works perfect at all speeds. And there is not much movement if I tug on it. If your bracket moves a lot then maybe that header that the base is screwed into is loose,,,,,maybe spray some foam behind it to stiffen it up. And do you have the factory mirror head,,,,those aftermarket ones just don't seem to give a solid view,,,,they just seem kind of blurry, factory ones seem to be kind of tinted......
    rear view mirror Repair70
    Post by Guest Fri Jan 29, 2010 2:17 am
    i asked because i see the divits where the base would mount so i will be looking for one now. thanks don
    Number of posts : 7900
    Post by DanTheVanMan Fri Jan 29, 2010 2:24 am
    rear view mirror Qr_cod10
    Post by Guest Fri Jan 29, 2010 2:41 am
    thanks dan
    Post by Guest Fri Jan 29, 2010 8:07 am
    i've got a second-gen rearview floating around here that i was going to massacre for an lcd mount (my van is a panel) when i find it, i'll shoot a pic or two. maybe you'd like it more than i do
    Post by DanTheVanMan Fri Jan 29, 2010 8:14 am
    I've got a second-gen out of the parts van complete with plastic cover. Going to put it in the 66....
    rear view mirror Img_0510
    Post by Guest Fri Mar 19, 2010 4:09 pm
    rear view mirror Vanmir10
    if someone is still looking for a factory rearview for a second gen - here it is, plastic and all. PM if you're interested.
    Post by DanTheVanMan Sat Mar 20, 2010 4:05 am
    Those are petty hard to find in good condition Copenhagenfiend!!!!
    Mine cleaned up very nicely!
    rear view mirror 03201010
    Dan
      Current date/time is Sat Apr 27, 2024 8:08 am
