by sasktrini Wed Sep 08, 2010 1:41 am
... after test driving with the new carb, I realized the mess on my driveway is tranny fluid! I didn't get very far! Also realized I had used the wrong fluid. So I drained my C4 tranny and torque converter, put an o-ring on the shift lever to cure the leak, and did a little detailing.
Just for kicks, here is a pic of the engine I'm rebuilding:
and so I detailed some bits I had forgotten (oil dipstick and distributor clamp), and also the tranny pan, filler tube and dipstick while I had them out...
Now, I realized that my Green Dot C4 never shifts into third gear... not sure what the deal is, but in my research, I learned what the different gears are supposed to do... P R and N are obvious... White Dot Drive is 2nd and 3rd, Green Dot Drive is 1-2-3, and L is 1. I hope to find third gear eventually, because I would like to get out on the highway!
In checking things out, I just want to put out there that I need a new Green Dot gear selector indicator, if anyone has one. Also, I can't send my steering column down there to be refurbished, but would like to get what it needs (lower spring washers, any bushings, turn signal switch, whatever). Also, when looking at my steering column selector lever, and it's very worn and doesn't grab the selecter detent plate well. I suspect I will have to weld and build it up, then cut it sharper to really grab the detent edges... I invite your thoughts on this.
I have seen Ron Blachut's steering wheel restoration, but I wonder if there are any other resources for doing this... like maybe using a ratchet strap and epoxy to restore the cracked up hub? I'm particularly curious because I hae a coveted white steering wheel.
Thanks all!
Last edited by sasktrini on Wed Sep 08, 2010 8:12 am; edited 2 times in total (Reason for editing : added pic)
