I discovered yesterday that the inside of my tank was in pretty bad shape with a few pin holes. The combination of sitting for for 30 years with fuel that turned to varnish and then going dry really did some damage. I considered flushing and then soldering...also considered cutting a section out to allow access to clean and then solder/braze/weld (would have to research best method) a fresh panel in. Very hard to justify all of that and having it done at a shop runs upwards of $150. No doubt that I couldn't do any of it but is it really worth it....
So I am seeking a solution for us A100 owners that have/will run into this problem. I'm doing some research with fuel cells and have found that there are ALOT of them on the market that are very close to our stock diamentions... at a very reasonable price. There are 2 choices... poly and aluminum and pretty much all of them come with sending units.
There are a few obsticles that we have to deal with...inlet location and fuel gauge are 2 of them. Then there there are fuel line/breather locations and mounting but I consider those very minor for anyone with some mechanical experience. A tray will more than likely have to be fabricated for the poly tank to rest on but it would be nice to find a tank that could simply use the factory mounting strap...thats why I'll more than likely use aluminum, so tabs can be welded in place for the factory strap to run in place and not let the tank wiggle (may add cross straping as a safety factor). I can also weld runners across the top so it can be spaced down to clear the fuel sending unit and return/breather lines.
I believe an inlet can be welded/bolted in the correct position leaving the stock cell filler in place, unused on the top. Using stock diamentions, the inlet is 3" from the end and 4" from the bottom but that will change once the tank size changes. The inlet will have to be determined once the tank has been test fit.
Probably the one thing that has me unsure is the fuel sending unit. Most aftermarkets operate at 0-90 ohm for the signal. I can't find anywhere what our As use for a signal. I guess I'll have to cross that bridge when I come to it.
So this is where I am at...all input is greatly appreciated and hopefully I can come up with a solution to a problem that haunts so many of us. When you consider the cost of a fuel tank repair and a new sending unit (over $200 combined) this may be the best solution since I have seen fuel cells sell for 25-50% less NEW with sending units
