    Front and rear axles from a '69 G10
    Adam K
    Adam K
    Number of posts : 8
    Registration date : 2020-06-16
    Front and rear axles from a '69 G10 Empty Front and rear axles from a '69 G10
    Post by Adam K Wed Nov 06, 2024 10:44 am
    I have the axles from my 1969 G10 that I no longer need. The front has, within the last 3 years, new kingpin and bushing set, tie rods, wheel bearings, brake cylinders, pads. Although, one side has an issue with the outer race being too small for the hub. I'm unsure if this is an issue with the hub, or if there are supposed to be two different bearings in the front.
    The rear seemed to be in good shape. It is covered in crusty gunk from the previous owner not maintaining a transmission leak and I assume riding down dirt roads. it has newish brake pads and cylinders as well.
    I'm asking $300 for the set of axles.
    Link to photos: https://photos.app.goo.gl/nrQc9RMKcvsB9Hbp8
    LMK if this doesn't work and I'll try and post some here.
    I also have some throttle linkage, free if you want it!
    I'm Located in Western Washington.
    WANTED:
    I'm on the hunt for a steering wheel for my second gen van. as well as a driver's side door panel...
    savage likes this post
    AzDon
    AzDon
    Number of posts : 758
    Front and rear axles from a '69 G10 Empty Re: Front and rear axles from a '69 G10
    Post by AzDon Fri Nov 08, 2024 10:26 am
    Thank you for posting your location.......
    For the rear axle, it will hep if you post whether it's 10 or 12 bolt and knowing the ratio will help.... You might reach out to Mark Burnitski in Sacramento (108 vanguy, I think) and see if he'd want the stuff....
    Adam K
    Adam K
    Number of posts : 8
    Post by Adam K Tue Nov 19, 2024 4:09 pm
    I'm unsure how to tell if this is a 10 or 12 bolt. I'm happy to pull the cover and check the gear ratio if anyone is interested. I believe it's 3.73 but I'm happy to verify.
      Current date/time is Mon Dec 09, 2024 3:36 pm
