    Part # for proportion vale
    Buggsy
    Buggsy
    Number of posts : 8
    Registration date : 2015-05-17
    Part # for proportion vale Empty Part # for proportion vale
    Post by Buggsy Tue Nov 30, 2021 10:42 am
    Converted front brakes with the Wilwood system and wanting to try and use a proportion valve without changing the MC. It's a '67 so it already has a dual reservoir. Any part #'s or thought to add? I know a lot of you have done this conversion, any ideas will be helpful......Good to be back here.
    13-ball
    13-ball
    Number of posts : 87
    Registration date : 2020-07-23
    Part # for proportion vale Empty Re: Part # for proportion vale
    Post by 13-ball Thu Dec 02, 2021 2:33 pm
    I'd probably get an adjustable one like this LINK HERE.
    You could try it with the MC you have then if you end up with a different one you'll already have the ability to adjust the bias front to back.
    There are various stock types you could try but they're each factory pre-set.  Adjustable valve allows you to play around with setting to dial in what feels good for the combination of how your vehicle is and your braking style.
    savage and gmytych like this post
    Number of posts : 8689
    Post by dix Thu Dec 02, 2021 6:33 pm
    i used the mc from a 1973 dodge b van , they had front disc rear drums but no booster so that valve might be your ticket
    hope that helps
    Dix..
    Buggsy
    Buggsy
    Number of posts : 8
    Post by Buggsy Thu Dec 02, 2021 7:36 pm
    Was there any cutting of the floor for the B MC?
    Thnks for all the help from both of you all
    gary h
    gary h
    Number of posts : 461
    Post by gary h Fri Dec 03, 2021 9:01 pm
    I have a nice used Prop.valve from a '68 van (Dual m/c) , For sale
    Post by dix Sat Dec 04, 2021 4:43 pm
    i did not cut the floor but i cut have to cut the bracket in front of the mc for it to fit was no big deal
    hope this helps
    Dix..
    gmytych likes this post
      Current date/time is Mon Oct 02, 2023 7:59 am
