Hey guys, got a few things that have been taking up space for years, and it's really time for them to go.
All currently located in Portland, OR, however, I can transport some stuff down to Nor/So Cal and LA area if you ping me by June 21.
Unpictured for the time;
$20
Driver/Passenger door shells, have been sitting out for a good while now
PS:: The doors are the thing I can’t transport, so those are Portland local only.
Stuff with pictures;
$100
10-bolt rear end, complete, RPO 3.36 Open, with barely used H1154 Dutchman half-shafts.
It has sat in the dirt for a few years so the brakes need a rework, and the drums need to be turned/replaced. Mercifully the seales held up so the internals are in great condition.
PS:: If somebody down yonder wants this, I can make it happen.
$25
Front axle, G10 (second gen, 5-lug)
Similar situation as the front, so really, this is best used as a starting point as it also needs kingpins redone.
$10
Belly pan... Yup.
$150
Saginaw 3-speed, with bell, and 10" flywheel. Came out of a '69 van.
I never opened the tranny case, doesn't feel loose. Flywheel does have scoring, however it's shallow and a resurface will take care of it.
Also note, 10" is the size of the pressure plate, the flywheel is a bit bigger than that.
$50
Steering column outer with 3-speed Manual shifter.
$50
Air-box, needs to be cleaned-up, no holes though.
$20
Anti-roll bar (sorry, no mounts or linkage)
$10
Window reg (Not sure of side...)
$20
$100
$25
$10
Belly pan... Yup.
$150
$50
$50
$20
$10
