+7
mcfly
wacko
11 posters
Roof Repair
- Number of posts : 12254
Roof Repair
wacko- Number of posts : 423
Re: Roof Repair
A question, the little square blocks that are located on the four corners of the roof, what purpose do they serve? Can they be eliminated? Mine are a little worse for wear, do I need to fab up some new ones? It would seem to me they hold the roof to the body, maybe while the spot welds were being done?
Re: Roof Repair
Re: Roof Repair
Are you talking about the littel clips on the rain gutters? If so, I eliminated them on my current project and just welded the pieces together. Thats always a place where rust starts.
VANagain- Number of posts : 1050
Re: Roof Repair
Thanks Don for the cutaway view of our roofs! Good to see how it all goes together.
The real question is, why are you doing this? What are you after, the roof pieces or the top of the door frame? And for which van?
Too bad we couldn't have salvaged that rust free roof we saw in the junkyard a while back. It would have been very doable to replace that rusty roof on Drew's van here in San Diego. All the welding would be hidden in the drip rail.
And I agree, those square things seem very unnecessary.
savage- Number of posts : 2632
Re: Roof Repair
I got a whole roof off a 1st gen Sportvan. Came inside 68 108 from Mark out in CA. Anybody(close) need one???
DanTheVanMan- Commissioner
- Number of posts : 7911
Re: Roof Repair
Don, I know we had discussed this awhile back but what Putty/Sealer did you use when you re-filled your gutters?
mcfly- Number of posts : 626
Re: Roof Repair
savage wrote:I got a whole roof off a 1st gen Sportvan. Came inside 68 108 from Mark out in CA. Anybody(close) need one???
Wish I were closer,the roof on my 65 looks like the Alantic Ocean.
mike
Re: Roof Repair
Drip rail rust is common out here on the West Coast. And I sure like taking stuff apart to see how it is put together anyways. And WideLoad just had a Van just sitting there with a Sawzall plugged in sitting next to it so I grabbed the section above the side doors and brought it home with me for evaluation,,,,,And I do notice a bad spot above the left rear door on the Blue No Door, so I got material to fix it if I want. And that caulk is called Seam Sealer, from Napa,,,,REALLY STICKY,,,,,I had a hard time laying it down then smoothing it out,,,,,,rubber gloves, an acid brush and Laquer thinner got it looking fairly nice,,,,,,,,
gotavan- Number of posts : 242
Re: Roof Repair
I have a van that suffers from roof rail rust... the entire roof panel blew off in a windstorm about 8 years ago
http://vintage-vans.smugmug.com/gallery/1885155_jmUZv#94975984_CbrMM
Re: Roof Repair
Re: Roof Repair
Thanks for the info guys, looks like I will eliminate the clips.
Re: Roof Repair
" And WideLoad just had a Van just sitting there with a Sawzall plugged in sitting next to it..." -sounds like a sign from God to me too...heh.
Re: Roof Repair
Yup...we were all just sittin around havin a big-ole-time,next thing ya know the sawzall comece to cuttin.Just glad it was the parts van sittin there.Heh heh
LiveWire64- Number of posts : 244
Registration date : 2009-03-17
Re: Roof Repair
Hey Don!
Thanks for the pics. I am in need of a roof for my 64. If I was to cut it across right behind the cab area, are the rain gutter spot welds all that holds the rest of the roof on? Also, what do you think about bracing the van before taking the roof off, to keep everything lined up & stable. Thanks,Brad
Re: Roof Repair
I would think bracing would be a verry good idea
Re: Roof Repair
How much are you going to do at a time? I would at least kind of hook a small chain to pull the 2 side rails in tight to keep the sides from spreading out just to be safe. But aside from the caulk in the drip rails, its just those spot welds holding the roof down. I doubt any of the cross ties are connected to the roof.
