+8
whalemstr
BILL Carson
JariV
busman78
rustytoolss
12 posters
    What gear ratio are you running ?
    lboast
    lboast
    Number of posts : 112
    Registration date : 2020-11-01
    What gear ratio are you running ? - Page 2 Empty Re: What gear ratio are you running ?
    Post by lboast Wed Dec 09, 2020 8:24 pm
    rustytoolss wrote:anyone else want to join in ?, looking for some input. santa rendeer
    I am also going to the highway gear ratio, to cruise, without worrying about stop light launches. I just installed a 2.70 ratio behind my 318 today. I should know next week when I put the  van on the road if i like it or not. If not i will change again, until i'm satisfied. I just visited Wildcat Auto Wrecking in Sandy Oregon yesterday, and they provided me with the speedo gears to correct the speed error with the new ratio, as well as a second rear seat, and other minor parts I needed.
    gmytych likes this post
    Number of posts : 8769
    Post by dix Thu Dec 10, 2020 2:33 am
    The 270's gear should do you good. i'd d love to find a 293 but they are hard to find.
    i think it's a 273 gear
    lboast
    lboast
    Post by lboast Thu Dec 10, 2020 9:45 am
    dix wrote:The 270's gear should do you good. i'd d love to find a 293 but they are hard to find.
    The person I got the 2.70 from had a lot of the gear ratio,s you are looking for. I could ask him if he wanted to part with one of them for you. What part of the country are you from? I,m in Central Washington State.
    lboast
    lboast
    Post by lboast Sat Dec 12, 2020 8:15 pm
    I just changed out my 3.55 gears for 2.70. When finishing up the project, I discovered that the rear Universal joint has too small of cups for the replacement gear set. A friend recommended an adapter u-joint by precision, part number 347. it has the correct width, with two of the original smaller cups and 2 of the larger ones for the differential. Is sure made that a amooth installation.
    Post by dix Sun Dec 13, 2020 3:03 am
    post the part # under this is how its done (dodge)
    lboast
    lboast
    Post by lboast Sun Feb 07, 2021 12:36 am
    lboast wrote:I just changed out my 3.55 gears for 2.70. When finishing up the project, I discovered that the rear Universal joint has too small of cups for the replacement gear set. A friend recommended an adapter u-joint by precision, part number 347. it has the correct width, with two of the original smaller cups and 2 of the larger ones for the differential. Is sure made that a amooth installation.
    I got to drive the van on the freeway with the 2.70 gears. With the 318 and automatic, it cruises at 75 real sweet, with lots of room left. I thing it would be ok in Idaho or Utah with the 80 MPH speed limit. The engine is not laboring at all. I haven't checked the mileage yet, but I will post that later.
    gmytych, vanny and rody8808 like this post
    rody8808
    rody8808
    Number of posts : 5
    Registration date : 2021-01-19
    Post by rody8808 Sun Feb 07, 2021 8:52 am
    Can you give an idea of what RPM's you are running at different speeds please?
    lboast
    lboast
    Post by lboast Sun Feb 07, 2021 10:50 am
    rody8808 wrote:Can you give an idea of what RPM's you are running at different speeds please?
    I can do that. right now I took it back apart a little doing some cosmetic paint work on it. as soon as I am driving it permanently.
    gmytych and rody8808 like this post
      Current date/time is Sat Nov 23, 2024 12:59 am
