    Wheel replacement
    tower9
    tower9
    Number of posts : 48
    Registration date : 2014-01-03
    Wheel replacement  Empty Wheel replacement
    Post by tower9 Wed Jan 08, 2014 9:16 am
    I did a search but couldn't seem to find an answer; so my questions is: Do you have to replace the left hand thread studs and lug nuts if you want to put aftermarket wheels on? Or can you just purchase the correct size / bolt pattern wheel and use the existing left hand thread lug nuts? Thanks in advance for any info.
    BADBADGER
    BADBADGER
    Number of posts : 246
    Post by BADBADGER Wed Jan 08, 2014 9:53 am
    You should not have to replace the LH studs as long as the lug nuts fit the aftermarket wheel properly and torque to the porper spec.
    Number of posts : 3046
    Wheel replacement  Empty Re: Wheel replacement
    Post by RodStRace Wed Jan 08, 2014 7:44 pm
    Check price and availability of the correct lug nuts for the wheels you are considering.
    Chrome reverse wheels take regular lug nuts. No big deal.
    unilug mags or other aluminum wheels that use shouldered nuts may be difficult or impossible to find left hand lug nuts for. There are different length shoulders and you must match lug nuts to the wheels.
    hoffy09
    hoffy09
    Post by hoffy09 Thu Jan 09, 2014 11:03 am
    Tower .... I have done the Skarebird conversion on the fronts and intentionally kept my left hand studs. I am running vintage Keystone Klassics and was able to purchase the correct lug nuts from the internet. There are several outfits that offer left hand shank nuts as well as barrel nuts. Just make sure you get (or already have) the proper nut for your style of wheel. Good luck!
    Number of posts : 8763
    Post by dix Thu Jan 09, 2014 3:14 pm
    The bigest problem is if you take your truck for tires brakes or inspection and a young blood puts a air wrench on it they may snap a stud or 2 before they figure it out, if you do all your own work or rememer to tell them then you would have no problem..
      Current date/time is Wed Oct 09, 2024 8:46 pm
