Dawgboy
    What Tires for a14" rim.
    Dawgboy
    Dawgboy
    Number of posts : 278
    Registration date : 2013-04-20
    What Tires for a14" rim. Empty What Tires for a14" rim.
    Post by Dawgboy Thu Oct 10, 2013 10:43 pm
    I have a 64 A100 with the 14" rims, I could really use some tire advice, What should I buy? I want to keep the 14s at least for now, and need to get some fresh rubber asap. What's a good size radial to run? I understand it was supposed to run Bias ply, but that's hard to find.
    I thought I saw a thread about this before, but could not find it.
    What Tires for a14" rim. Empty Re: What Tires for a14" rim.
    Post by Joe Van Fri Oct 11, 2013 3:06 am
    As far as tire size you can run 215/70/14 witch is about 25 inches tall or 225/70/14 witch is about 26 inches tall and is the tallest tire you can put on the front axel without rubbing.Smile . As far as tires go I have had the best luck with the Cooper Cobra Gt Radials.!!!!!!!!!!!.(I have 215/70's up front on mine)
    Dawgboy
    Dawgboy
    Post by Dawgboy Fri Oct 11, 2013 10:02 am
    Really? It seems pretty cavernous under the fenders. A 70 series is as big as I can go? I plan on bombing this thing down a lot of dirt roads and was thinking of going with BFG AT2s. Sure would like some meat between me and the roadbed. Also concerned about load ratings.
    Number of posts : 12188
    Post by donivan65 Fri Oct 11, 2013 11:36 am
    Discount tire has this chart that shows all the size differences between tires,,,,,but the width of the rim limits how wide a tire will ride and wear properly,,,,,,,,,
    http://www.discounttire.com/dtcs/infoTireMath.dos
    What Tires for a14" rim. Discou10
    Dawgboy
    Dawgboy
    Post by Dawgboy Fri Oct 11, 2013 11:50 am
    Yeah, I went through that chart last night, but i was not sure what was optimal for this van. Also, they have very little selection, so I am going to have to order them, and i really want to make sure I do that part right. The cooper sounds decent, I was told I could get it in a 60 series, but I like a tall tire that I can air down in the soft stuff...
    Post by Joe Van Fri Oct 11, 2013 2:14 pm
    Donivan is right you are really limited to how wide your rim is.!!!. I have 275/60/15 on the rear of mine but they are on a 10 inch wide rim.. What LOOK are you going for.??? (Do you want all terrains?? Cooper has the AT3"s you can go 225/70/14 all around).OR you can run 215/70/14 on the front and 245/60/14 on rear (street tread) with stock rims and should give you plenty of wheel well clearance for off road and plenty of width in the rear for traction also.!!!!! I get the best on and off road traction with the Cooper Cobras I have had BF Goodrichs for many many years and have had quite a few that the belts have separate a year or two down the road and the Company would not pro rate it plus a couple of blow outs also.!!!! The Cobras hold 44 lbs max and Bf Goodrich is only 35 lbs max plus I did not do very well in the sand with the BFG'S (street tread) and I have a posi in my 3Rd Gen also but if you are dead set on them they should work fine either way keep us posted.Smile ........
    Dawgboy
    Dawgboy
    Post by Dawgboy Tue Oct 15, 2013 7:50 am
    Picking up 2 tires today. I could not find anything locally that I could get installed bigger than a 207/75/14r, and am getting 2 so that they will match the front.I had bias on the back and radials up front... The radials have about 40,000 miles to go before they are worn out... By then I hope to find some15" slots...
    Dawgboy
    Dawgboy
    Post by Dawgboy Wed Oct 16, 2013 7:23 am
    FYI, the guys at Discount won't put a tire on the stock 14" rim bigger than a 205 width. I ended up getting 2 205/75/14s on there, and they are not great tires... So I guess I am on the search for rims before my fronts are worn out...
    Post by Joe Van Wed Oct 16, 2013 1:52 pm
    The first number (205) is how tall the tire is the second number(75) is how wide the tire is  the last one is the rim size(14). so 215/70/14 would be about a inch taller than the 205/75/14 you have now but you CAN fit a 225/70/14 on a stock rim it would be 2 inches taller and about 1/2 inch wider than the ones you just bought.Smile .  Most all Ford Ranger pick up's take 225/70/14 on there trucks from the factory with the 14 inch stock rims.
    Number of posts : 956
    Post by slowflapper Thu Oct 17, 2013 11:47 am
    Dawgboy wrote:FYI, the guys at Discount won't put a tire on the stock 14" rim bigger than a 205 width. I ended up getting 2 205/75/14s on there, and they are not great tires... So I guess I am on the search for rims before my fronts are worn out...
    I went to the Discount Tire by my house and had four Cooper Cobra 225/70/14's put on my van. No issues at all with clearances etc and they they look good. If you have deep pockets you can get Mickey Thompson Indy Profile bias plys from Summit Racing.
    There were some steel 14" rims in my van when I got it that had 205?/75/14's on them but they were dry rotted so I never ran them.
    What Tires for a14" rim. XUQhcbVNR3Nvsu-eHGWUZfy4a-V3Y2c5kQhK3zP0zr4=w958-h719-no
    What Tires for a14" rim. IMG-20110413-00350
    Dawgboy
    Dawgboy
    Post by Dawgboy Thu Oct 24, 2013 9:48 am
    Those slots look sweet, That's what I had on my '74 Wagoneer. Miss that truck.
    ditdater
    ditdater
    Number of posts : 590
    What Tires for a14" rim. Empty 14s
    Post by ditdater Sat Jul 16, 2016 12:23 pm
    [quote="donivan65"]Discount tire has this chart that shows all the size differences between tires,,,,,but the width of the rim limits how wide a tire will ride and wear properly,,,,,,,,,
    What Tires for a14" rim. Discou10[/quote
    As my 65 sportvans getting prepped to paint , just picked up a like new set of 14x7 chevy rallys ,   looking real hard at the 215/75/r14  Optima 80,000 mile white wall tire (at $62.00 ea.), have you heard of anyone out that way try this tire or the size on a 1st gen , to hear of how it stance is w stock suspension ?
    gary h
    gary h
    Number of posts : 460
    Post by gary h Mon Jul 18, 2016 11:22 pm
    Find out where they are made. Anything cheap is made in China or some other country that has poor standards. I would not use Asian Tires on my cars ,trucks or vans!
      Current date/time is Fri Sep 29, 2023 9:50 am
