hey gang. can anyone measure ther a100 radaitor for the 318? the one i too out is 2952843. it says a w200. did anyone put in an aftermarket one? did it fit, mods? im stuck on the this one. thanks wile...
radiator - the rite one?
wylee- Number of posts : 917
- Number of posts : 8726
Re: radiator - the rite one?
when i did the engine swap i useda allum. rad from F.S.R. it has 4 ports 2 in and 2 out. it is used in the airport equipment that tows the airplanes around. called a tug. the rad does fit .if you look at the photo it has a allum. c channel on each side. you would have to cut one side of the c channel off and re drill the holes .But it's not that hard. call them and they can help you... http://www.fsrradiator.com/
lws67- Number of posts : 193
I just got a 2 port FSR yesterday for my slant engine A, $299 shipped. Part# 155360 It is about 4" shorter than the oem, but width is basically the same. Nice welds, fitting it now. I'll take pics during the install.
Lorin
Lorin
made in u.s.a. ....
Got it installed today, I have a "van load" of pictures to upload of how I installed mine. It is rubber mounted to keep vibration to a minimum. Sat idling for awhile, stays at about 195 (never done that before!), and down the road it sits at 180 (w/180 thermostat) Tomorrow down the highway in 100+ degree heatwave will be the real test. I'll start a new thread with all the pics if anyone is interested in that??
Lorin
Lorin
thanks guys, i got in touch with fsr nice peapole to work with. gona order mine tomorow. thanks for yas help............
oo3- Number of posts : 290
thread with pics yes - i think quite a few of us would be interested -oo3
Flange to Flange is 23 3/8"
The core is 18 1/2" X 21"
Top of the neck to the bottom is 26 1/4"
Hope this helps ya out.
it helps very much duane, thanks............
most rads are wider than tall that is were the glitch is at . trying to cind the core that is tall enough.
