I have no power too the fuze box but I do have power too the silonoid but no power? I have too red and one black lines at the dash and one red at the silonoid and one black that leads too the alt am i missing a wire?
No power too the starter or fuze box
Rybo- Number of posts : 24
- Number of posts : 12218
The Positive battery cable probably goes to the starter relay,,,,,then smaller wires connect to it and go out to feed the rest of the truck,,,,,do you have an ammeter in it? see if the wires on it are tight,,,,,,do any of the fuses have power on them?
The amp meter was lose and I had power then lost it if the amp meter is bad will that kill power too everything?
All the power from the battery has to 1st go through that useless ammeter,,,,,you can take off 1 of the wires on the back of the ammeter and move it over to the other one so both wires are hooked together and see if your life gets better,,,,,
