+12
64chevy
64vanatic
ViewMaster
16 posters
Rear Sway Bar
- Number of posts : 12218
Rear Sway Bar
I got this rear sway bar off a 83 Firebird. It looks like it has the potential for mounting on vans. It has 2 U bolts that hold it on the rear end and 2 brackets that mount the links to the frame. So drill 4 holes in the frame and you are done. But you probably need to make a couple of adjustments to mount it. My van is jacked up so I need longer links or have to build some brackets to reach down from the frame to mount that link bracket.
savage- Number of posts : 2625
Re: Rear Sway Bar
Looks like a real good fit Don. They have a 1/2 price day at the pick a part(sure wish they do that here)
ViewMaster- Number of posts : 117
Re: Rear Sway Bar
That looks great Don! That would help a lot with passengers eyes opening so wide when there is 4 of them in the back and taking a curve.
Again a great fix to one of our obsolete problems.
Re: Rear Sway Bar
Re: Rear Sway Bar
Nice find Don.
Damn, they whack you almost another 20% on the core charge. BASTARDS!
Vanish- Admin
- Number of posts : 5155
Re: Rear Sway Bar
Don..... Fits like a Glove ....... Nice........
,,,Vanish,,,
MCMLXV
DanTheVanMan- Commissioner
- Number of posts : 7899
Re: Rear Sway Bar
Nice find Don. and a great fit too....
Re: Rear Sway Bar
wylee- Number of posts : 917
Re: Rear Sway Bar
very ,very cool!! great job. thanks for posting .
crazee- Number of posts : 331
Registration date : 2009-02-24
Re: Rear Sway Bar
SURE WOULD make a great sticky in the "G VAN" section huh?
64vanatic- Number of posts : 18
Registration date : 2009-10-03
Re: Rear Sway Bar
how long are the end links on that?
Re: Rear Sway Bar
Since I have the rear end of my van raised up, I used a 10 inch long, 3/8" carriage bolt and cut a 5 3/4" section out of 1/2" solid conduit tubing to make the center spacer,,,,you kind of want to have the sway bar ends sit level with the ground for best performance........
Re: Rear Sway Bar
Re: Rear Sway Bar
i need o hit the scrap yard and try to find one.
- Number of posts : 8726
Re: Rear Sway Bar
AFTER SEEING THIS POST A FEW WEEKS AGO I STARTED LOOKING ON CRAIGSLIST ONLY TO FIND SOMEONE GIVING ONE AWAY . HE REPLACED HIS REAR-END SO HE ENDED UP WITH ONE ON THE NEW REAR-END!! ( NEW END LINKS WERE $ 7.00EA) THE SWAY BAR WAS ALSO ON THE 85 I-ROC.
64chevy- Number of posts : 364
Re: Rear Sway Bar
Re: Rear Sway Bar
23mm????? talk American, Joe,,,,,,,,,,
- Post n°19
Re: Rear Sway Bar
Half way between 7/8" and 15/16"
- Post n°20
Re: Rear Sway Bar
I have a rear sway bar from an f250 ford pick up and the diam is
about the same size, haven`t measured it but mounts the very same
but without the frame brackets. maybe the f350 truck would be even bigger?
- Post n°21
Re: Rear Sway Bar
Cool idea for a simple mod on rear sway bar! Hmm, so that were meant for early chevy vans? Donivan65... tell me, did your van come with rear tire that way by the factory originally? Or was that another one of your little mods ?
The brackets you made to fasten on frame with the sway bar - to me, the brackets seem not strong enough by the look. Were they enough to take up all the stress?
- Post n°22
Re: Rear Sway Bar
The Chevy Vans did not come with rear sway bars, and most did not with front ones either, basically just the passenger carrying, SportVans. And they good to have if you carry anything to improve handling. I just seen that a Firebird kind of had the same shape of what would fit under my truck. My Van is jacked up in back, so I had to make those extended brackets to mount the links to. They are 3/16" thick and wrap around the frame,,,,all they got to do is pull and push on those links, and so far no problems,,,,,but if they do bend, I will make them out of 1/4" flat stock. And since the body is raised up back there, my 15" spare tire fits right above the differential. It is out of my way,,,,,,I would have to undo the u bolts on the driveshaft and move it over to the side to drop the spare down. But it is worth not tripping over or seeing that spare tire always hanging around,,,,,
mbasaraba- Number of posts : 823
- Post n°23
Re: Rear Sway Bar
Dredging up an old post, hope you dont mind.
I want to ask about the mechanics behind this sway bar. Since Tammy will be driving her 66 as a daily with her and 4 kids I want to get it as stable as possible. Junk yards here in Alabama suck! I have gone to a couple and they say "Tell us what you need and we will see if we have it" then they charge part store prices.
I am wondering if this could be made more like a link than a full bar. Have the part that mounts to the frame similar but on the rear end mount fashion a mount like a shock mount with a piece of tubing with a bushing and a bolt through it.
Does it have to be a solid bar running the width of the rear end?
I am also thinking about this kind of link for the front end since our Sportvan doesn't have a front sway and it would need to be dropped for a dual master cylinder anyways.
- Post n°24
Re: Rear Sway Bar
I have seen ones on mid/late 80s to early 90s ford
3/4 ton trucks that clamp to the rear axle housing
similar to a muffler clamp and then used link kits
up to the frame, very basic and simple to adapt.
Lazarusvan- Number of posts : 1293
- Post n°25
Re: Rear Sway Bar
Just pulling this thread up since it hasn't been discussed for a while. Digz mentioned his rear sway bar and thought this would be a nice addition for anyone looking to put in a rear sway bar since factory examples never existed. It also answers my question on what else works, at least in the same family of cars.
