Digz's 65 panel
Re: Digz's 65 panel
Post by G-Man on Wed Jun 01, 2011 4:43 pm
Joe the interior looks great, and that spare tire with the orange caps is just Bad Ass
Scotts_A100
Number of posts : 160
Re: Digz's 65 panel
Post by Scotts_A100 on Thu Jun 02, 2011 6:37 am
Joe,
That's a nice take on the peace sign. All that cold weather work and time you put in sure turned out to be worth it, just in time for the summer cruise time too. Great job. Scott...
Number of posts : 2067
Re: Digz's 65 panel
Post by sasktrini on Thu Jun 02, 2011 10:20 am
Great stuff... just now catching up on the wood speed nut idea!!! Loving it!!!
Number of posts : 3736
Re: Digz's 65 panel
Post by Digz on Fri Aug 01, 2014 2:58 am
I see it's been ages since I posted anything in this thread so...
My 40$ Ebay carb has finally seen it's better days ! LOL I learned that finding a rebuild kit locally was almost a joke and my Ace In The Hole shop said "I don't work on those things", apparently to old.
So I ordered a remanufactured Edelbrock 1406. Should be here today. Just thought I'd post a few pics of the prep to get it off .
Carb is off now but I had to do some real work so the reat later and I hope that was my problem !! And please ignore my birds nest wiring and plumbing.. Never said I was good at detail stuff.
Number of posts : 1860
Re: Digz's 65 panel
Post by savage on Fri Aug 01, 2014 4:33 am
Hope your new carb solves your problem. Always liked your van and all the Major work you did to get it Back on the road
Re: Digz's 65 panel
Post by Joe Van on Fri Aug 01, 2014 8:32 am
WOW..!!!..cheers.. What a Build.."Great Job"... It sits .."Just Right"..That Orange paint on the gauge cluster looks Really Good.!!!..
Re: Digz's 65 panel
Post by Digz on Fri Aug 01, 2014 4:59 pm
Got it on and running. Pretty sure I need new plugs before dialing it in all the way. Got rid of my High end loaded POP. A little flat off the line and some stuttering at cruise ,feels more like a miss/sparkplug hiccup tho. First couple of runs were fantastic other than the flat spot on take off and that was not that bad.
Re: Digz's 65 panel
Post by Digz on Sun Aug 03, 2014 4:51 am
Pretty sure I found my culprit, #7 plug boot was burned through right next to the header. Couldn't see it until I changed the plugs and pulled the wire off. So next project ,New wires with 90* ends. Just turned the burn away from the pipe for now ,LOL. Don't know what I was thinking when I put these on in the first place. Not going to brag up MSD wires though.
Number of posts : 7983
Re: Digz's 65 panel
Post by dix on Sun Aug 03, 2014 5:09 am
LOOKS GOOD DIGZ , I LIKE THE COLD AIR INTAKE, DID YOU MAKE IT ???
Re: Digz's 65 panel
Post by Joe Van on Sun Aug 03, 2014 5:17 am
Yea the 90* ends are the way to go with "headers" you can turn them away from the pipes..Smile...Digz...How much lift is on your front springs over the stock ones??? I am getting ready to redo mine again the 2 inch re arch lasted only a year its almost back where it was before I did it....
Re: Digz's 65 panel
Post by Digz on Sun Aug 03, 2014 5:55 am
Dix, that intake set up was around 16$ off Ebay. Think it is for a 2000's Dodge truck. Made in mejico I think. Came with a straight piece, 1 angle, air filter and bonnet with a couple choices for holding it down. I had WAY more into the 2 Spectre elbows I had to add than the rest of it. I used 3" no-hub bands (plumbing stuff) for the connections, the blue silicone sleeve came with it.
Joe, I over compensated a bit on the fronts at a 3" over on NEW springs. The rears were 1" over because I figured I could run air shocks if needed, hasn't needed them yet. The front has settled down some because my shocks will now reach the original mounting location. That is important because my crappy mounts I made for the upper didn't treat the wheel wells good. I couldn't find longer shocks without them being fatter and they interfered with the disc brake and sway bar ends. If running stock brakes and no swaybar a set of Ranchos would work. Or fab some extensions that utilize the original upper shock mounts some how. BTW I am running stock front shocks on the rear also.
suicideking
Number of posts : 68
Re: Digz's 65 panel
Post by suicideking on Sun Aug 03, 2014 7:59 am
You put a lot of work into this project. Looks great man.
Re: Digz's 65 panel
Post by Digz on Sat Aug 23, 2014 8:00 pm
Discovered a broken nipple on the overflow tank today. My 5 dollar yard sale bargain finally bit it !!
I have been saving this one for whatever reason so I gained some Bling ! Of course in a spot it will never be seen . LOL
Re: Digz's 65 panel
Post by Nightmoves on Wed Aug 27, 2014 2:43 pm
a much nicer look,Joe.
Re: Digz's 65 panel
    Current date/time is Sat Jan 20, 2018 9:00 pm
