AzDon's 108
AzDon
AzDon
Number of posts : 395
AzDon's 108 Empty AzDon's 108
Post by AzDon on Thu Nov 28, 2019 11:12 am
I first dragged my 108 home in 2014...…. What I'm in the middle of is a re-engineering project....This van will be getting a TBI 454 and 4L80 trans out of a 95 Suburban which will be placed 18 inches back from stock..... the front of the existing doghouse will be cut down so the driver seat can be moved inboard so it's in line with the steering column....It has already received a front axle flip..... Here are some pics from 2014 when I first got it...
AzDon's 108 First-11
AzDon's 108 Rear-411
AzDon's 108 Left-s11
Number of posts : 651
AzDon's 108 Empty Re: AzDon's 108
Post by samsvan on Thu Nov 28, 2019 4:21 pm
You still got the pickup? I'd like to see some pictures of that.
AzDon
AzDon
Post by AzDon on Thu Nov 28, 2019 4:47 pm
This pickup?
AzDon's 108 94dual10
AzDon
AzDon
Post by AzDon on Thu Nov 28, 2019 4:53 pm
Or maybe you caught a glimpse of the front of the burb(?)AzDon's 108 Burbnl10
AzDon's 108 Burb-l10
With the pickup in the background in the second pic...
AzDon
AzDon
Post by AzDon on Thu Nov 28, 2019 5:19 pm
More 69 van pics:
AzDon's 108 Stance11
After the axle flip with some cool wheels/tires
AzDon's 108 Inside10
and an interior shot before the cutting started...
AzDon's 108 Old-en10
AzDon's 108 Box_go10
AzDon's 108 Old-do10
And I'm into it now!
AzDon's 108 Floor_10
AzDon's 108 Big_ho10
AzDon's 108 Cut_do10
Number of posts : 1945
Post by savage on Tue Dec 03, 2019 10:01 am
Your going to have a Sweet van with all your improvements.
My 65 with the BB is set back about 18 in. PO did all the fab work.
AzDon's 108 00411
AzDon's 108 00611
AzDon
AzDon
Post by AzDon on Sat Dec 07, 2019 7:06 am
18 inch setback in a 90wb van?? Does it have a driveshaft? Or is it some kind of close-coupled deal?....
I'm using a 4L80 and a posi out of a 91 wagon that has a longer pinion snout and expect my driveshaft to be 14" cup-to-cup...…
I have several reasons for wanting to do the 18" setback:
1) Better engine accessibility thru the side doors for service and display
2)Full factory serp belt system can be used because it'll be behind the seats
3) seats can be moved inboard so driver seat is aligned with the steering wheel
4)More spacious front bay for coolers, fans, a stabilizer bar, and air bags (should that become necessary)
5)better overall airflow design of the inside of the  engine/cooler box with better dispersement of radiator heat from a bit rearward and lower of the stock placement for driver/passenger comfort...
6)The challenge of engineering and executing something a bit different Wink
Post by savage on Thu Dec 12, 2019 12:24 pm
Don, its has a (about) 12 inch drive shaft & a rear end out of (what I Think) 57 Chevy carAzDon's 108 01110
AzDon's 108 01010
AzDon
AzDon
Post by AzDon on Sun Dec 29, 2019 7:01 pm
So my last couple of pics featured the axle flip and the engine crossmember mocked in....The slots in the floor are where I dropped in 2 ft pieces of 2x2x1/4" square tube with the vertical holes for the engine crossmember drilled for 2 half inch bolts per side... Currently using the crossmember as a step to get in and out of the hole to work;)     Also the rad crossmember laying loose as I was trying to develop a plan for a new one incorporating a stabilizer bar mount, which also now includes an underpan/scoop setup and relocated master cylinder..... So let's look at some more pics!....
AzDon's 108 Right_11
This is a picture of the right frame mount and rail designed to mount all the previously mentioned stuff.... The mount bolts into the original holes for the rad crossmember, the stabilizer bar bolts fasten the rail to the bottom of the mount and the rail also incorporates a plate that is drilled to bolt to the front of the spring perch...
AzDon's 108 Bar_an11
Here is the right side setup mounted with the stabilizer bar.... Note the welded spring perch setup bolted in....
AzDon's 108 Right_12
AzDon's 108 Right_13
Here's two pics showing the right side mount.....Mirror images of these parts were simultaneously made for the left side and installed..... Most of the holes were tapped with threads....
AzDon's 108 Master14
Here is the half-finished bellcrank box for the relocation of the master cylinder...
AzDon's 108 Old_ma11
AzDon's 108 Old_ma12
These 2 pics show where the master cylinder had been...If you look back several pics you can see the master cylinder in the original location... In these pics, you can see the left side of the hump in the Jeep Cherokee stabilizer bar that would hit the master in it's original location....It had to move!....
AzDon's 108 Master15
AzDon's 108 Master16
AzDon's 108 Master17
So here's 3 more pics showing the new bellcrank and master cylinder mount... The last pic it's mounted on a crossmember that bolts to the top of those bar-mount rails right behind the grille in the basic vicinity of the throttle arm....
AzDon's 108 Lovvre11
AzDon's 108 Louvre12
AzDon's 108 Louvre13
So while I was mounting the master, I realized that those two rails were perfect to build and hang an underpan/scoop from..... Because the axle flip has put the front end VERY low, the lowest tier of the scoop could go no further forward than the spring perches, which would have left a big open gap above. The upper tier of the scoop is on the bottom of the rails, two inches below the valance, and the valance has an underpan that also screws into the master cylinder crossmember.... The setup is designed to act the opposite of louvred windows... That each tier has air being forced underneath by the next lower tier, so that none of the velocity leaks out the bottom.... The bottom tier ends where the bottom of the radiator will be...Note also that the top tier is screwed to the inside of the rails, while the bottom tier slips over the outside of the rails and bolts inward so that the bolts will be accessible to remove the bottom pan for serviceability above it.... Also note how the side rails of the bottom pan are trimmed to fit the stabilizer bushings....Also note the new master cylinder location in the second pic... The hole to the left with light coming thru near the left side of the stabilizer bar hump is where the master was originally bolted. The brake pedal originally pushed the rod rearward into the master. Now it pulls the bellcrank arm rearward...
AzDon
AzDon
Post by AzDon on Sun Dec 29, 2019 7:07 pm
Next up will be the radiator mounts....
Number of posts : 12212
Post by vanny on Mon Dec 30, 2019 6:17 am
Mad skills Don! Looking forward to seeing what comes next...Does Skechers Sneakers now make van parts also??? scratch
AzDon
AzDon
Post by AzDon on Sun Jan 12, 2020 7:34 pm
More Pics!
So now I gotta mount the new aluminum radiator....
AzDon's 108 Radiat10
AzDon's 108 Radiat11
AzDon's 108 Top_ra10
These three pics show the radiator fully mocked up and bolted into it's new mounts....the top mount pieces still need to be smoothed and painted and the top and bottom mounts will have rubber sandwiching the radiator when installed permanently......I took extra time to design thread mounts so they can be pre-fastened to the rad and the whole assembly can be slipped up in from underneath and "hooked" in place before coming topside and 'finishe securing with two bolts and two hook-bolts...… The 28 inch wide radiators can't be pulled out through the top- hafta go in from the bottom, so I wanted to make future serviceability from underneath easy...So lets look:
AzDon's 108 Rad_mo10
AzDon's 108 Pieces10
AzDon's 108 Right_14
First pic shows (top to bottom) the top radiator "hat" bracket, The cross-bar that bolts into the van that the bottom mount hangs on, and the bottom mount that has the hooks on the front made out of square tubing..... also note the eye bolts installed on the bar and their caps.... the eyebolts are now hook bolts for easier installation....
Second picture show the hooks over the bar with the eyebolts up the center...
Third pic shows bottom and top connected by four pieces of 3/8 allthread and shows the right bar hook...…
AzDon's 108 Rt_rad10
So here is the bar bolted into the back end of the right stabilizer bar and rail mount left side is mirror image.....
AzDon's 108 With_a10
This is a full pic of the front side of the radiator with top and bottom mounts fastened with four pieces of allthread… note caps for eyebolts...
AzDon's 108 Rad_ho10
This pic shows the left hook over the bar with the eyebolt inside.... after this test fit, it was decided that the eyebolts would become hook bolts....    The final phase was adding brackets up top in the front of the engine box to secure the top of the radiator in place (third overall pic in thread)….. Now it all comes back apart for paint and to provide me access to build shift and throttle linkages and to paint and insulate everything.....
AzDon
AzDon
Post by AzDon on Thu Jan 30, 2020 5:16 pm
Next logical step here is to build a fan shroud to mount an electric fan.... I'm undecided whether to use a stock 16 inch fan from an 82-85 z28 camaro or whether to take a chance on aftermarket (flex-I-lite)……..
Taking a break from that, I built a throttle assembly that will pull a 33c marine cable under the floor below the pedal from a bellcrank arm above the pedal..... it will all make sense once I post pics!.....I wanted the range of the pedal to start in a position that isn't as upright as the factory placement and I will be able to rest my heel on the hump that the stock throttle shaft was under.....
While I wasn't busy, I also have created a shifter assembly that will allow use of the factory reverse-first gate to shift an automatic transmission while setting the crossover gate with the lower arm to the "park" position so that the shifter will "drop in" to the neutral gate when the shifter is pushed to about 1.5 inches from the dash...….The assembly I built positions a 43c marine cable.....
I discovered an easy adjustment that can be made to the factory shifter that locks out the R1 gate completely if somebody wanted to simply use the 2-3 gate to shift their automatic, but that would just use the detents in the trans only (including park)
I've gotta get busy with my camera and get some pics up....
AzDon
AzDon
Post by AzDon on Thu Feb 06, 2020 7:08 pm
Wellllll…...I'm changing the shifter from what I described above to instead bolting the two gates together solid and using the transmission detents only.....Still going to use a 43c cable.....
Also still working on the throttle to get the geometry as I want it to be......this entails raising the hinge up under the arch of my foot and lengthening it to eleven inches to include a heel so that I can rest my foot on the pedal and rock my foot to operate it.... similar to a flatbottom boat throttle....I also added a return slide so that standing on the heel will pull the throttle back.....I'm creating a lot of scrap metal! (and a few usable parts too)
    Current date/time is Thu Feb 20, 2020 3:21 pm
