    Busted Junk
    sandyvan
    sandyvan
    Number of posts : 526
    Busted Junk Empty Busted Junk
    Post by sandyvan Mon Sep 09, 2019 4:19 pm
    I crawled under the van to check out something else and discovered a busted sway bar link on the driver's side.  Amazingly I later found the broken off pieces were laying in the street outside my house.  I showed the broken bolt to Donivan and he pointed out it was not a Grade 8 bolt suitable for a suspension part.  I wasn't able to locally source a replacement bolt but I found the following repair kit at NAPA with the correct bolt and sleeve length for my 1st Gen.  Pricey, but Made in USA high quality.  Only took a half hour or so to replace both sides.
    Busted Junk For_po11
    Busted Junk For_po10
    Busted Junk For_po12
    Busted Junk For_po13
    Busted Junk For_po14
    Busted Junk For_po15
    Number of posts : 12218
    Busted Junk Empty Re: Busted Junk
    Post by donivan65 Mon Sep 09, 2019 6:22 pm
    Wow Ted,,,,,,you just increased that SportsVans value,,,,,,
    Number of posts : 1778
    Post by m1dadio Mon Sep 09, 2019 7:49 pm
    Yes the bolts in the kit are grade 5 or better. A lot stronger than that Grade 2 threaded rod that was there. No wonder it broke.
    M1D
      Current date/time is Thu Mar 28, 2024 7:20 pm
