I find a lot of synthetic blend Brake Fluid on the market now. What would you suggest to use if staying stock with no conversion? What would equal Rontunda's R-103-A on todays market?
Appreciate the input!
Okay, I will pass on the synthetics and use the DOT 3. It has been awhile since I have any Econolines and just started back into it. I appreciate the reply!Seth G wrote:DOT 3 is spec
