Looking for some feedback on my 250 C4 swap into a 63 Econo PUP. Everything I've read says you have to cut the back of the doghouse for bell housing clearance and you need to use an engine cross member.
What I have mocked up is a 1 1/4" spacer between the engine perches and the frame to lower the engine. This gives me 1/4" clearance to the dog house with a 5 degree engine angle. Also had to drill holes in the perches to accommodate the extra engine width. Using a trans dapt cross member with fabricated plates that will be welded to the frame rails for the rear trans support.
Any thoughts? Am I missing something?
