+4
sandyvan
8 posters
    What changed year to year?
    Number of posts : 1651
    What changed year to year? Empty What changed year to year?
    Post by Scott Thu Oct 25, 2018 8:21 am
    One for the Chevy / GMC people..
    Considering 1964 the base model, what changed year to year after that?
    In other words, what can I look for on the body to tell what year I am looking at?
    Fell free to add what you know to this list, like tire size options, and engine options. Like I think 1964 had an engine option of 153 or 194..?  And tire size options of 13" or 14"?
    What year did they add reverse lights?
            1964: Base
    Early 1965:
    Late  1965: Added additional grill cutout
            1966:
            1967: Front Panel Redesign, Add 108" wheel base option
            1968: Added Side Marker Reflectors
            1969: Changed Side Markers to Lighted
            1970:
    Number of posts : 1388
    What changed year to year? Empty Re: What changed year to year?
    Post by wideload Fri Oct 26, 2018 4:36 am
    '66 was first year for reverse lights
    Number of posts : 801
    Post by panelmanrd Fri Oct 26, 2018 6:07 am
    67 first year for the v8 option also rear lights
    are a new design for the vans
    heavy duty cross flow radiators are new
    redesign of the springs front and rear
    redesign of the dash board
    sandyvan
    sandyvan
    Number of posts : 526
    Post by sandyvan Wed Oct 31, 2018 2:06 pm
    1st and 2nd gen have different bumpers, different tail light and backup lenses.
    G20's have front drums that are no longer reproduced - :-(
    Post by Digz Thu Nov 01, 2018 7:08 pm
    I think on the panel vans they lost the lateral ribs on the inside in 65. I have only seen the extra weight for the rear gas tank support on 64s also but I don't know for sure on that.
    Post by vanny Thu Nov 01, 2018 7:25 pm
    Great thread, I love this stuff!!! Keep it going... Twisted Evil What a Face
    Just found this online...
    First Generation/Origins (1964-1966)
    The first General Motors van was the Chevrolet Corvair-based Chevrolet Greenbrier van, or CorVan introduced for 1961, which used a flat-6 opposed rear engine with air cooling, inspired by the Volkswagen bus. Production of the Chevrolet Greenbrier ended after the 1964 model year.
    The 1st generation ChevyVan refers to the first Chevrolet G-Series vans G-10 1/2 ton production years 1964 through 1966. General Motors saw a market for a compact van based on a modified passenger car platform to compete with the already successful Ford Econoline and Dodge A100. The 1964 ChevyVan had a cab forward design with the engine was placed in a "doghouse" between and behind the front seats. Engines and brakes were sourced from the Chevy II, a more conventional compact car than Chevrolet Corvair. The forward engine design allowed a flat rear floor with low deck heights in the rear of the van for loading/unloading cargo. This model was also sold by GMC as Handi-Van. The 1st Gen vans were available in only the short 90 inch wheelbase and were only sold with the standard 90 hp 153 cubic inch straight-4 or Chevrolet Straight-6 engine. A first gen is quickly identified by its single piece flat windshield glass. The first 1964 ChevyVan was originally marketed and sold as a panel van for purely utilitarian purposes. Windows were available as an option, but were simply cut into the sides from the factory. In 1965, Chevy added Sportvan which featured windows actually integrated into the body. GMC marketed their window van as Handi-Bus. Air conditioning, power steering and power brakes were not available in the 1st generation vans.
    Updates
    1964
    The original "classic" flat windshield van. The 90 hp (67 kW) 153 cu in (2.51 L) four-cylinder engine was standard equipment with optional 120 hp (89 kW) 194 cu in (3.18 L) Chevrolet Straight-6 engine engines available. The straightforward construction and a boxy design was ideal for economically hauling cargo, tools and equipment around town. The base cargo model was the ChevyVan, available with or without windows and side cargo doors. Even the heater and right front passenger seat were optional. The Saginaw 3-speed manual transmission was standard with column shift. A 2-speed Powerglide automatic transmission was available as an option.
    1965
    For 1965, the van remained largely unchanged. The grille received one additional slot just above the bumper to increase cooling. Seat belts were added. The exciting news for the 1965 model year was the introduction of the Chevy Sportvan and GMC Handi-Bus. Sportvan was a passenger friendly van with windows molded into the van body. A retractable rear courtesy step for the passenger side doors was used on the Sportvan. The 194 6 cylinder engine was now standard equipment, with an available 'Hi-Torque' 140 hp (100 kW) 230 cu in (3.8 L) six-cylinder
    1966
    This was the last year of the Flat glass front end on the Chevy Vans. Changes for 1966 include the addition of back-up lights, the side ChevyVan emblems were moved forward and now mounted on the front doors, and the antennae location was moved from passenger side to driver side. The base model "Sportvan" now had two additional trim packages available: Sportvan Custom and Sportvan Deluxe. These featured available upgrades such as Chrome bumpers, two tone paint, rear passenger seats, interior paneling, padded dash, chrome horn ring.
    Second generation (1967–1970)
    In 1967, ChevyVan got a facelift, including moving the headlights down to a new grille, different tail lights and a rounded glass windshield. The forward control cab design was retained, but the doghouse was widened and slightly relocated in order to fit an optional Chevrolet Small-Block engine. Engine cooling was improved with the addition of a larger cross-flow type radiator and a redesigned front floor which allowed more fresh air to the radiator. The 2nd gen vans were available in either the 90" or the longer 108" wheelbase. Power steering and "conventional" air conditioning (with dash vents & controls) were never available on the 2nd generation vans.
    1967
    1967 begins the "Second Generation", ChevyVan with a whole new look to the van and offering long wheelbase and v8 power to buyers for the first time. GM designers moved the headlights down to a new grille, added longer, rectangular tail lights and a rounded glass windshield. The forward control cab design was retained, but the doghouse was widened and slightly relocated in order to fit the optional V8 Chevrolet Small-Block engine. Engine cooling was improved with the addition of a larger cross-flow type radiator and a redesigned front floor allowing even more fresh air to the radiator. The 2nd gen G-10 vans were available in the original short wheelbase 90 inches (2,286 mm) or the new optional long wheelbase 108-inch (2,743 mm). Another feature in 1967 was the availability of a new G-20 heavy duty 3/4 ton van. The G-20 featured heavier suspension, a 12 bolt rear axle and increased hauling capability. The G-20 model was available only on the 108 long wheelbase. For 1967, the 140 hp (100 kW) 230 cu in (3.8 L) six-cylinder was now standard, with the optional 155 hp (116 kW) 250 cu in (4.1 L) six-cylinder or the 175 hp, 283 cu in (4.64 L) 2 barrel, V8. Brakes were now upgraded to a safer split system including a dual reservoir master cylinder.
    1968
    This was the first year that Chevy Vans had side-marker lights. The front lights were located towards the front in the middle of the front doors, while the rear marker lights were located about a foot inward of the very back edge just below the vertical middle of the van.
    The optional V-8 engine was upgraded from the 283 2-barrel (175HP) to the larger, more powerful 307 2-barrel V8 (200HP @ 4600 RPM).
    A column shift 4-speed transmission (Warner T10) was now available as an option.
    1969
    For the 1969 model year, the van remained relatively static.
    The 3 speed TH-350 Turbo-Hydramatic automatic transmission and power brakes were now available. "Body-integrated" air conditioning was available on 1969 Sportvan models. This was not your typical AC setup with dash vents and controls, but rather a roof-mounted unit with an single blower duct that had adjustable louvers to direct air flow. Up front, the Chevrolet bowtie emblem changed in color from red to blue this year.
    1970
    1970 was the last year of the square styling, front drum brakes, and I-beam front axle. The 250 CID 6 cylinder (155Hp @ 4200 RPM) was now standard equipment. In addition to the 307-2 barrel V-8, a 350-4 barrel (255HP @ 4600 RPM) V-8 engine was available as an option for the first time in 1970. The 3 speed automatic and manual 4 speed column shift continued to be available as transmission options.
    savage likes this post
    Post by Scott Sat Nov 10, 2018 8:46 am
    What we have so far..
    What Changed from year to year?
    1964 is the base model, what changed year to year after that?
    • 1964 (First Generation)
      • Base
        • Chevy G10 ‘ChevyVan’ or GMC G1000 ‘Handi-Van’
        • ½ Ton
        • Flat Glass Windshield
        • 90” Wheelbase
        • “Chevy Van” chrome marker behind the front side doors
        • 153 cubic inch Straight 4 (90 HP)
        • Saginaw 3-speed manual transmission with column shift
        • NOTE: Brakes were sourced from the Chevy II
      • Optional
        • Side Cargo Doors
        • Side Windows: Cut in to the sides at the factory, not molded into the body
        • Wheel Sizes of 13” or 14”
        • Heater
        • Front passenger seat
        • 194 cubic inch Straight 6 (120 HP)
        • 2-speed Powerglide automatic transmission
    • 1965 (Early)
      • Base
        • Seat belts were added
      • Optional
        • 230 cubic inch Straight 6 (140 HP) ‘Hi-Torque’
        • Chevy Sportvan or GMC ‘Handi-Bus’
          • Side Windows molded into the body
      • Retractable rear courtesy step for the passenger side doors
    • 1965 (Late)
      • Base
        • Additional Grill cutout added just above the bumper to increase cooling
    • 1966
      • Base
        • “Chevy Van” side emblems were moved forward and mounted on the front doors
        • Antennae location moved from passenger side to driver side
        • Reverse Lights added
      • Optional
        • Sportvan
          • Trim Packages:
            • Sportvan Custom
            • Sportvan Deluxe
            • NOTE: These featured available upgrades such as
              • Chrome bumpers
              • Two tone paint
              • Rear passenger seats
              • Interior paneling
              • Padded dash
              • Chrome horn ring
    • 1967 (Second Generation)
      • Redesigned
        • Rounded windshield glass
        • Headlights moved down to either side of a new grille
        • Dash shape
        • Doghouse widened, and slightly relocated
          • NOTE: This was done to fit the optional Small-Block engine
        • Front floor redesigned to allow more fresh air to the radiator
      • Changed
        • Gauge Cluster (Nova)
        • Cross Flow Radiator
        • Bumpers (front / rear)
        • Leaf Springs (front / rear)
        • Rectangular tail lights
        • Square reverse lights
        • Cross-flow radiator
        • Brake Master Cylinder changed to Dual Reservoir
      • Base
      • Optional
        • 108” Wheelbase – Base Model
        • 108” Wheelbase – G-20 Heavy Duty ¾ Ton
          • Heavier suspension
          • 12 bolt rear axle
          • 6 Lug Wheels
          • Increased hauling capability
          • 250 cubic inch Straight 6 (155 HP)
          • 283 cubic inch V8 / 2-barrel (175 HP)
    • 1968
      • Base
        • Side Marker Reflectors added
      • Optional
        • 307 cubic inch V8 / 2-barrel (200 HP @ 4600 RPM)
        • Column shift 4-speed transmission (Warner T10)
    • 1969
      • Base
        • Side Markers changed to lighted
        • Chevrolet Bowtie Emblem changed in color from red to blue
      • Optional
        • 3 speed TH-350 Turbo-Hydramatic automatic transmission
        • Power Brakes
        • Sportvan model
          • Air Conditioning: "Body-integrated" air conditioning was available on 1969 Sportvan models. This was not your typical AC setup with dash vents and controls, but rather a roof-mounted unit with a single blower duct that had adjustable louvers to direct air flow.
    • 1970
      • Base
      • Optional
        • 350 cubic inch V8 / 4-barrel (255 HP @ 4600 RPM)
    Post by vanny Sat Nov 10, 2018 4:12 pm
    Good Job, this makes a nice reference for the Chevys...Now we need someone to do this for the Fords and Dodges...
    lboast likes this post
    Number of posts : 155
    Registration date : 2011-02-01
    Post by Jay 13 Thu Nov 15, 2018 1:46 pm
    Base price for a 1964 was $2067 which was $145 less than the base price Corvan. The same year Corvan had a base engine with 95HP with an optional 110HP both from a flat 6cyl.VS the G10 base 90HP 4cyl or optional 120HP 6 cyl.
    AzDon
    AzDon
    Number of posts : 741
    Post by AzDon Sun Feb 10, 2019 6:11 pm
    The brake sizing was actually Chevelle (not nova)
    No mention of the different lock configurations for the front doors.... First gen had lock cylinder push-button on the outside door handle and the inner handle would drop the striking surface out of line with the outer push-button when you pushed the inner door handle forward..... two separate systems that operated separately...If you locked from the inside handle the outside button would not work... If you locked the button, you could still use the inside handle to get in and out……... Second Gen moved the lock cylinder from the door handle to a separate location on the door and was operated on the inside by a conventional lock plunger.....
    AzDon
    AzDon
    Post by AzDon Sun Feb 10, 2019 6:20 pm
    The Corvan was weird simply by being a Corvair…. And it was, um, not beautiful...…. But if you have ever looked one over carefully to compare with a g-van...… The Corvan bodywork is much more solid and engineered.... The front doors have hidden hinges and shut solid like a car.... They also have independent suspension, front and rear and ride closer to the road....
    Post by Scott Sat Sep 04, 2021 8:16 am
    Update: At a recent Van show I parked next to a 67 G10 and noticed that in 1968 they moved the windshield sprayers to the center of the window. I've since looked at several more 68's and 67's and it looks to be consistent.
    Base
    • ½ Ton
    • 90” Wheelbase
    Optional
    • Side Cargo Doors
    • Heater
    1965 (Early)
    Base
    Optional
    1965 (Later)
    Base
    • Additional Grill Cutout added just above the bumper to increase cooling
    1966
    Base
    Optional
    Sportvan Trim Packages
    1. Sportvan Custom
    2. Sportvan Deluxe
    Sportvan packages featured the following available upgrades.
    • Chrome bumpers
    • Two tone paint
    • Interior paneling
    • Padded dash
    • Chrome horn ring
    Redesigned
    • Dash shape
    • Doghouse widened, and slightly relocated to fit the optional Small-Block engine
    Changed
    Base
    Optional
    NOTE: The G-20 included the following.
    • 12 bolt rear axle
    • 6 Lug Wheels
    1968
    Base
    • Windshield Sprayers were moved to the middle.
    Optional
    1969
    Base
    Optional
    • Power Brakes
    • Sportvan model
    1970
    Base
    Optional
      Current date/time is Fri Apr 19, 2024 12:23 am
