Wall Insulation
soccer7
soccer7
Number of posts : 9
Registration date : 2014-04-23
Wall Insulation Empty Wall Insulation
Post by soccer7 on Tue May 22, 2018 7:35 am
I have a 65 Chevy G10 van and used 10 mil self adhesive insulation on my doghouse and front floor to cut down on heat and noise and it worked real well.  Think it would be okay to use it on the cargo walls or is there a moisture concern?  Help I need suggestions
Number of posts : 12154
Wall Insulation Empty Re: Wall Insulation
Post by vanny on Tue May 22, 2018 3:57 pm
If you use the search tab you can find quite a few discussions about insulation including this one:
http://vintage-vans.forumotion.com/t37947-interior-wall-insulation?highlight=insulation
Hope this helps, if not, there are quite a few threads to look through...also, someone who has used this may jump in and offer up what they found also. I'm interested in hearing more about this subject as well;
Number of posts : 237
Post by Keith D on Mon Jun 24, 2019 9:51 pm
Ever considered a spray on product like Lizardskin (lizardskin.com) or Eastwood makes a similar product.
Also good information at
https://www.hotrod.com/articles/1969-dodge-a100-heres-how-to-kill-noise-and-heat-in-your-prized-machine/
Keith
Number of posts : 815
Post by JackeFriend on Wed Jun 26, 2019 8:03 am
I did use Lizard skin sound proofing spray. Did my entire van inside floors to ceiling. It did make a big difference in the noise levels when driving. It was a good product. I then used a pre cut insulation package from Quiet ride solutions. It is cut to fit our vans, which is nice. The kit comes with everything you need. I did my whole van in about two hours hours.
Post by Keith D on Thu Jun 27, 2019 4:02 pm
Good to know that you are happy with Lizardskin as I am considering using their sound deadening and heat insulation products.
How many gallons did it take do the interior of your van?
Post by JackeFriend on Thu Jun 27, 2019 4:41 pm
I used two gallons I did everything including ceiling all doors, floor, walls. I bought the 2 gal kit with paint sprayer. It comes with everything needed.
You should check out Quiet Ride Solutions for the heat insulation materials. The kit is cut to fit our vans, saves time and effort. I also bought the plenum for the front fire wall. If you look at my pages the entire thing is documented. Good luck on the projects!
Post by Keith D on Thu Jun 27, 2019 5:27 pm
Thanks for the information.
Turns out Quiet Ride Solutions is about a hour and half or a little less from my house.
Post by JackeFriend on Thu Jun 27, 2019 8:33 pm
Wow great, no shipping charges. They have a nice product, much better than what else I researched.
I have a V8, so I actually put muffler titanium wrap around the inside of the lid which touches my area.
Then I insulated it. They actually have a motor box insulation kit. But I did not purchase that... I bought everything else however.
But, check about your year and make, hopefully they have it too.
Number of posts : 1361
Post by OutofSight on Fri Jun 28, 2019 8:41 am
Appears as they do, thanks for the info. Not cheap, but what is any more.
    Current date/time is Tue Jan 28, 2020 7:46 am
