Sandblasting
Stomper
Stomper
Number of posts : 22
Registration date : 2013-01-18
Sandblasting Empty Sandblasting
Post by Stomper on Mon Feb 05, 2018 6:44 pm
I was told by a vintage vehicle restorer not to sandblast my van, as it will warp the sheet metal. Thoughts?
Number of posts : 1892
Sandblasting Empty Re: Sandblasting
Post by savage on Mon Feb 05, 2018 7:54 pm
Sand blasting creates heat,that's what warps the metal. A friend had his 65 GMC soda blasted.
Number of posts : 3774
Post by Digz on Tue Feb 06, 2018 12:36 am
You can use one on the rigid areas. Like by drip rails and hard curves. Just stay away from big flat areas.
64chevy
64chevy
Number of posts : 321
Post by 64chevy on Tue Feb 06, 2018 10:44 am
Find someone in your area that does Dustless Blasting. They're awesome. Fast paint and old bondo removal and no chance of warping. Usually around an hour to completely strip a vehicle. And they add a rust inhibitor to the water that gives you 72 hours to get an epoxy primer on to protect the bare metal.
Post by Digz on Tue Feb 06, 2018 8:18 pm
Sandblasting Frtbls10
Sandblasting Fuelho10
Sandblasting Rtrqtr10
Some of the stuff I sand blasted. As a DIY'er I used chemical stipper, paper and a bunch of 2" scotch pads also.
Post by savage on Wed Feb 07, 2018 6:44 am
Chevy primer is Hard to get off,wonder if its got lead in it??
Hate to think how much I have inhaled.
Post by Digz on Wed Feb 07, 2018 9:27 am
savage wrote:Chevy primer is Hard to get off,wonder if its got lead in it??
Yeah , no kidding , LOL Even the air craft stripper barely dents the stuff.
Number of posts : 82
Post by uncle ron on Wed Feb 07, 2018 9:53 pm
lot of work but you could use a sander .Sandblasting 10310
Number of posts : 1740
Post by m1dadio on Mon Feb 19, 2018 7:09 pm
best to sand or other abrasive blast only the bottom and around the hard to sand areas like the window frames and door jams. Then use a DP sander with about 80 or 100 grit and sand the paint off the flat areas. if the paint is old it will sand off easier than one might think. in fact mine with original sun faded paint sanded to the steel faster than you could sand blast it.
Stomper
Stomper
Post by Stomper on Tue Aug 14, 2018 10:15 am
On a semi-related note, how are the roof support rails attached to the roof? The roof in my van is pretty much completely separated from the supports (and rattle like crazy). Is there a fool-proof strategy for reattaching them?
Number of posts : 1582
Post by Scott on Tue Aug 14, 2018 10:43 am
I don't think want the rails to attach to the roof. The sun beating down on it will cause it to expand. If it was spot welded it would buckle and warp. On mine I took a strips of plastic and shoved them between the ribs and roof to stop the rattle.
Number of posts : 796
Post by panelmanrd on Wed Aug 15, 2018 11:44 am
3m has a product that is called fast and firm it is a
seam sealer in a caulking gun tube, I used this product
between all the ribs and outer skin in my van, stopped all
the rattles, it is not meant to glue it togeather just stop the
vibration of both metals.
    Current date/time is Wed May 22, 2019 8:26 am
