independent front suspension
dougtappan
Number of posts : 262
Post by dougtappan on Thu Jan 11, 2018 3:04 pm
Has anyone put IFS in a G van
67VanHelsing
Number of posts : 96
Re: independent front suspension
Post by 67VanHelsing on Thu Jan 11, 2018 3:32 pm
I've seen one or two that I can remember. From what I gather the stock frame was cut out completely and a new frame fab'd to work with the IFS. I'm sure there's at least on this site
dhuglife
Number of posts : 10
Registration date : 2015-09-03
Post by dhuglife on Thu Jan 11, 2018 8:57 pm
theres two builds that i have been following of guys of doing it, i believe one is labeled bagged 1966 g van and the other is ifs under a 65. hopefully soon i will be posting about mine as well i am weeks away from starting mine and am doing it by cutting out the entire floor of the van and using a modified s10 frame
Soo fine customs
Number of posts : 3
Registration date : 2016-09-03
Post by Soo fine customs on Fri Jan 12, 2018 4:14 pm
I have a 65 van with a c-4 corvette frame under it. Still working on it. It Can be done. Shortening the wheelbase on the Corvette chassis. Cut out the doghouse split the front wheel wells cut the rear wheel wells because of the rear kick up and have kept the stock floor in the rear. Corvette frame sits right inside the rockers have to cut out a couple pieces of the stock unibody frame to make it work.
Number of posts : 655
Post by vanner68 on Mon Jan 15, 2018 8:53 pm
Frank Costa put a C5 corvette suspension under his 65, Number 9. So far this is the only one I have personally seen finished and driving.
    Current date/time is Sun Jan 21, 2018 10:15 pm
