My 3 in the tree shifter or linkage is making loud squeaking noises when shifting 2nd to 3ed, and 3rd to 1st. How do I lubricate this set up. Thanks
squeaking shifter or linkages
steelrat- Number of posts : 116
Registration date : 2014-11-24
Canada17- Number of posts : 49
Registration date : 2016-03-21
Re: squeaking shifter or linkages
There is a zerk fitting on the shift tube housing. Its accessible through the grill. Start there and then work your way back, you may be grinding on the radiator bulkhead which will require some new bushings to make go away.
Thanks so much! I thought I would ask before climbing under and looking about. Great helpful info.
- Number of posts : 2086
It can also be rubbing where it goes through the frame bracket in the doghouse area.
Old Skool- Econoline Guru
- Number of posts : 1306
