Body work is finally done!
misterbee- Number of posts : 70
Registration date : 2014-12-30
jrdunn96- Number of posts : 690
Re: Body work is finally done!
How long will your driveshaft be?
- Number of posts : 2086
Mine is 15.75", but with a 302 maybe a bit longer if you keep the engine forward?
Congrats Misterbee!!! It's been a lot of work and a long time in the making! What color are you going to paint it?
You may consider an AODE if there's still time to swap the trans. It's an inch longer and requires a $400 controller, but with it you can controll all the shift points electronically. What rearend ratio are you going to run?
Other Details
The driveshaft hasn't been ordered yet since the shop is trying to decide how far back to position the engine. The engineer feels that the further back it can go, the better the handling. The current thought is to move it back 6-8" and fabricate a small bubble that will extend into the bed.
A Holley Terminator EFI set-up is already bought as are big Willwood discs at all four corners.
As for color, the ePup will be metallic teal up to the beltline and pearl white above . . . a nod to 60s colors. Then, a gold pinstripe separating the colors I think.
AODE isn't in the cards since the AOD is already bought and paid for. I going to put in a Lokar floor shifter (at least it kind of looks like a stick!). I REALLY wanted a 5-speed, but I was told it is really challenging unless you do a shift by wire set-up.
The steering column will be Flaming River painted metallic teal (as will be the rest of the inside of the cab).
I'm working on selecting gauges. The shop likes Stewart Warner, but I prefer the Autometer gauges.
We are hoping to have it done by World of Wheels in Chicago in March 2018. This is the third year of the restoration!
