Recently replaced the fuel pump on my 170 due to oil spraying from weep hole ON TOP of the pump onto surrounding sheet metal & brake lines on drivers side. No idea how old this pump was.
New (rebuilt) pump worked for 30 days/50 miles then it started to leak similar.
Guys at auto parts store have nothing to comment, everything I have read states when it leaks out the weep holes a seal or diaphragm is bad.
I wish I had taken the first one apart to see what is in the top of the pump body in relation to the weep hole to confirm.
Did I just get a bad part or is there something more going on?
