by Old Skool Tue Sep 12, 2017 12:26 pm
IMO,,,, its TWICE the motor!!!!! The torque is much better and allows a greater range of gearing. I replaced a fast 240 with 3;50 gears,, but always looking for another gear at 80 because of the gearing.
Dropped to 3:25's and it would start to die going up a long hill and down to 2nd gear. Blew it up and installed a 300. Cruised all day long a 80 no problem and drove up the SAME HILL at 80 instead of dropping down to 2nd. The torque is fantastic and had considered dropping down to 3:00 because of it.
The 300 uses a dampener bolt and the fan will hit it but an easy fix using a 1/2" spacer between the fan and the water pump hub. Also dual belt so you can easily upgrade to a 3G alternator...
Just be aware that all the big sixes were heat generators and gas percolation issues with the exhaust bolted to the intake manifold. Stock exhaust DO NOT PUT ANYTHING PLASTIC next to the passengers side rear part of the doghouse,,LOL
VicSoCal
