Can someone decipher this code?
dougw1
dougw1
Number of posts : 29
Registration date : 2017-04-05
Can someone decipher this code? Empty Can someone decipher this code?
Post by dougw1 on Fri Sep 08, 2017 12:43 am
I have a 2004r trans from a bone yard that I would like to put behind a 292 in my van I'm redoing. I've seen there seems to be a few who have done the trans swap to the 4 speed auto. I've seen lots of reference to the numbers on the tag riveted to the trans but can't find anything about the number on this one. It is supposedly out of a 84ish monty carlo. It has the dual bolt pattern housing. haven't seen anything with the H E code. I've found many Chev blogs but no mention of this. Has anyone seen this code or can anyone come up with a link to where it many be?
Thanks
Can someone decipher this code? Fullsi17
kookykrispy
kookykrispy
Number of posts : 1483
Can someone decipher this code? Empty Re: Can someone decipher this code?
Post by kookykrispy on Fri Sep 08, 2017 2:11 am
"'84 HE is Caprice, DeVille, Impala, LeSaber, and Parisienne w/ V-8 305" 5.0L Canada.
Got the info from an AC Delco parts catalog"
source: https://www.turbobuick.com/threads/200r4-transmission-codes.223081/
dougw1
dougw1
Post by dougw1 on Sat Sep 09, 2017 10:07 am
Thanks Kookyk. I was kinda hoping it would explain more if it was a good on or just a typical 200.
I found a site that talked about putting in a positive pressure valve body from TCI that eliminates the need for the TV cable to be set to control the pressure. If I understand it correctly, by using this PPVB, the TV cable is only used for kick down to passing gear. Not sure about the TC lock up yet, haven't got that far yet.
Doug
    Current date/time is Wed May 22, 2019 8:05 am
