What is this called
G-10 Ron
G-10 Ron
Number of posts : 46
Registration date : 2016-05-15
What is this called Empty What is this called
Post by G-10 Ron on Thu Jul 27, 2017 6:23 am
What is this tank called?What is this called Inkedt15
Number of posts : 11364
What is this called Empty Re: What is this called
Post by vanny on Thu Jul 27, 2017 7:49 am
I believe that's called an overflow or surge tank What a Face
G-10 Ron
G-10 Ron
Post by G-10 Ron on Thu Jul 27, 2017 7:51 am
ok thanks thought so just making sure.
Buddyr
Buddyr
Number of posts : 18
Registration date : 2015-10-08
Post by Buddyr on Thu Jul 27, 2017 11:25 am
Also try expansion tank. I think that's how you spell it.
G-10 Ron
G-10 Ron
Post by G-10 Ron on Thu Aug 03, 2017 7:09 pm
Here's mine before and after. Wish I knew how to take the dents out! After pics. areWhat is this called Night_13
What is this called Night_12
What is this called Tank_a17
What is this called Tank_a15
What is this called Tank_a16
What is this called Tank_a14
crappy!
Post by vanny on Fri Aug 04, 2017 12:22 pm
Looks like it cleaned up real nice...I'm sure someone will chime in with a trick for getting those dents out...How about one of those stud welders. If they stick to brass, which is what I'm assuming that tank is, you could weld a few studs on there and then use the pulling tool to pull them out???
Number of posts : 620
Post by samsvan on Fri Aug 04, 2017 12:36 pm
Put a firecracker in it...
Number of posts : 796
Post by panelmanrd on Tue Aug 08, 2017 10:36 am
I thought that's how you leak tested them
Number of posts : 11710
Post by donivan65 on Tue Aug 08, 2017 4:27 pm
take it off and Pump air into it or fill it with water and put it in the freezer,,,,water expands,,,,,,,
    Current date/time is Wed May 22, 2019 7:50 am
