Early Econoline V8 swap exhaust sugestions
sdgreene81
Number of posts : 9
Registration date : 2017-04-16
Post by sdgreene81 on Sun Jul 16, 2017 5:45 pm
I am almost ready to start fitting the engine into the van and before I completely get everything final welded, I would like to see what types of exhaust systems others has used. I am thinking about standard long tubes for a f100 or should I go with the standard long tubes for a car setup. I have also thought about shorty headers but I would luke to go with full length. What are your thoughts?
Wolfster
Number of posts : 139
Registration date : 2016-08-27
Re: Early Econoline V8 swap exhaust sugestions
Post by Wolfster on Mon Jul 17, 2017 3:05 am
I used long tube headers. Rest of the exhaust system is about 2 weeks out on the to-do list.
Old Skool
Number of posts : 1251
Post by Old Skool on Tue Jul 25, 2017 9:18 am
Been a while posting but saw this thread and thought I needed to add some info as I have been doing conversions for a long time now.
  In building a roller motor I found the cost of updating a set of GT40p heads to what is needed to be just better off purchasing a high end set of aluminum heads. Regular type screw in studs and roller rockers instead of the harder to set push rod length pedestal type studs, also having the DUAL pattern larger exhaust bolt pattern which is stronger and easier.
  However the next issue being the dual pattern and I thought I would take advantage of being able to make them larger but still having a hard time finding a set of headers to fit???????
  With that I took my new cylinder heads to WEST COAST RACING CYLINDER HEADS to have them ported out to a larger size.  Boy did I learn some information !!!!!!
  I was told that the SBF needs the smaller ports to help unless I was running at Daytona and high RPMS all day long.  He also told me that the shorty headers are okay for a computer controlled motor as the ECM can compensate for the camshaft tuning in detail and so long tube headers can be used. He emphatically told me to NOT enlarge the exhaust ports and for the best running that the long tubed headers would work better as there is not computer to fine tune everything like shortys were designed for????????
  As always a higher quality header also includes that the welding on the mounting plate be done on the GASKET SIDE and then polished down so that it can IMPRINT into the gasket material to avoid leaks. That as always also to use 3/8" thick flanges instead of the weak 5/16th headers.
vicSoCal
Old Skool
Post by Old Skool on Tue Jul 25, 2017 9:30 am
?Sorry,,, forgot some pics,,  CORRECT push rod length controls pivot point on valve tip and helps prevent worn valve guides regardless of rocker arm type. Note the wider mounting hole pattern which is much easier to get at.
VicSoCal
sdgreene81
Number of posts : 9
Post by sdgreene81 on Mon Sep 11, 2017 2:35 pm
Thanks for the information Vic it really has give me insight. I am going to go with the long tubes and will definitely try out the welded flange.
    Current date/time is Wed Aug 15, 2018 8:28 am
