What carb is this ???
Zonk 1/75
Number of posts : 80
Registration date : 2016-06-24
Post by Zonk 1/75 on Sat Jul 15, 2017 6:20 pm
Sorry for the weird angles..... Click on image for bigger view
This is on a 250
Markings :
D5OE
9A589-BA
Made by Carter for Motorcraft
There is no ID tag
What is it ?????
Thanks!
gfleduc
Number of posts : 156
D5OE Carb
Post by gfleduc on Sat Jul 15, 2017 7:09 pm
jdlaugh
Number of posts : 263
Re: What carb is this ???
Post by jdlaugh on Sat Jul 15, 2017 8:14 pm
carter yf or yfa, more likely yfa. Good single-barrel carb found on 70s era sixes. I had one on my 240 and it did fine. Should also be a good basic carb on a 250. Didn't come standard on the early Econolines, but neither did the 250....
Zonk 1/75
Post by Zonk 1/75 on Sun Jul 16, 2017 8:34 am
gfleduc wrote:Check out a vendors site:
http://www.carburetion.com/CarbNumber.asp?Number=D5OE-HA
Although the "D5OE" matches, and the era is correct, the image at this link looks dissimilar.
Also, I believe mine is a single barrel and the one at the link (a F2-2150) is a two barrel.
Number of posts : 1912
Post by Seth G on Mon Jul 17, 2017 11:05 pm
Yeah that link is to a 2100 carb. Where are the #'s located Zonk? There should be # stamped onto the base. D5 is Ford 1975, I couldn't find a reference for D5OE. Are you sure you are reading it right? I think that number may be the number of the ford carb base, not the carb itself. This video shows where to look for the carter #,
https://www.youtube.com/watch?v=Kz3p76vtCyE
    Current date/time is Wed Aug 15, 2018 8:28 am
