67 MC brake switch
Linoman
Number of posts : 329
67 MC brake switch
Post by Linoman on Mon Jun 05, 2017 5:34 pm
Hi all been awhile since I 've posted, although I do check in periodically.
Anyways, the MC on my 66 was leaking quite a bit so I swapped in a 67 MC I had. I need a diagram of how the mechanical brake switch connects up to it so I can get the van back on the road. Many thanks. ~ Tim
Number of posts : 1912
Re: 67 MC brake switch
Post by Seth G on Mon Jun 05, 2017 9:02 pm
I think the wiring is the same it's just a mechanical instead of hydraulic switch, at the brake pedal level instead of on the mc
Linoman
Post by Linoman on Tue Jun 06, 2017 3:52 am
The wiring is not an issue, I want to make sure I'm putting the switch on correctly so it does it's switchy thing when I depress the brake pedal because it is not lighting the brake lights the way I have it. I did jump the circuit and lights do work.
Linoman
Post by Linoman on Wed Jun 07, 2017 3:13 am
Figured it out, van is back on the road!
Number of posts : 10025
Post by vanny on Wed Jun 07, 2017 5:04 am
Congrats Linoman! Great to hear you've got it back on the road!!! cheers
scarlin
Number of posts : 258
Post by scarlin on Thu Jun 15, 2017 4:10 pm
Linoman, See you at Bakers?
KISSfan
Number of posts : 98
Registration date : 2016-08-23
Post by KISSfan on Thu Jun 15, 2017 5:39 pm
The brake lights in my '67 only work occasionally. Tail lights are fine, hazards are fine....bad switch? If so, do they still make them???
Linoman
Post by Linoman on Fri Jun 16, 2017 12:01 pm
KISSfan, They still make the switch, my problem was I wasn't attaching it to the MC correctly.
scarlin, I'll only be at Bakers if I can afford new tires, while working on the brakes I noticed the current tires are very weather checked, so no out of town driving on them.
Old Skool
Number of posts : 1251
Post by Old Skool on Tue Jul 25, 2017 9:44 am
Here you go,, reposts,,,,,,
VicSoCal
Wolfster
Number of posts : 139
Registration date : 2016-08-27
Post by Wolfster on Tue Jul 25, 2017 3:02 pm
Vic, how much for the vise and to ship to Omaha?
joking.....
Old Skool
Post by Old Skool on Tue Jul 25, 2017 9:36 pm
Still laughing,,,,,, bounce bounce
    Current date/time is Wed Aug 15, 2018 8:29 am
