http://www.ebay.com/itm/1964-Ford-Other-1-2-Ton-Van-Custom-/222494053723?hash=item33cdadd55b:g:mYkAAOSww9xZBiuB&vxp=mtr
look at the bill for parts and labor!
62stationbus wrote:http://www.ebay.com/itm/1964-Ford-Other-1-2-Ton-Van-Custom-/222494053723?hash=item33cdadd55b:g:mYkAAOSww9xZBiuB&vxp=mtr
Wolfster wrote:Yeah it is. Installing one in mine.
Seth G wrote:Idk why, but it always irks me when the f o r d emblems are removed, it just doesn't look right to me.
Zonk 1/75 wrote:Wolfster wrote:Yeah it is. Installing one in mine.
Ididit brand?
Barnabas wrote:Seth G wrote:Idk why, but it always irks me when the f o r d emblems are removed, it just doesn't look right to me.
My first Econoline was missing the F O R D from the front. I found out it was because the whole nose was Bondo. Whenever I see the F O R D missing, I assume the nose is Bondo.
Wolfster wrote:Zonk 1/75 wrote:Wolfster wrote:Yeah it is. Installing one in mine.
Ididit brand?
No. Got if off of ebay. I've used the same column in about 5 different builds with never a problem. One was a keyed column. I like this brand because of the different lengths available. The one going in the Econo is a 28". Reason is because you have to account for a steering shaft connector or u-joint to connect the DD shaft on the column to the round shaft coming out of the steering box. I'm using a u-joint that will weld onto the steering shaft and then has set bolt screws for the column DD shaft. If I or someone ever has to remove the steering box, just loosen the screws on the DD shaft. Not that hard of a modification.
jrdunn96 wrote:Wolfster wrote:Zonk 1/75 wrote:Wolfster wrote:Yeah it is. Installing one in mine.
Ididit brand?
C'mon Wolfster, you got me interested. How about some pictures?
Thx,
Jim
