Steering box
Vangoat
Number of posts : 41
Steering box
Post by Vangoat on Sun Jun 04, 2017 4:01 pm
Does anyone know where I can purchase a rebuild kit for my steering box, seals and worm gear adjuster. My adjustment seems to be maxed out, think a new one might tighten it up more. 61 econoline. Thanks !
DaGroats
Number of posts : 40
Re: Steering box
Post by DaGroats on Mon Jun 05, 2017 8:00 am
If I remember correctly, I bought the roller bearings and seals for a Falcon from C & G. I bought the bronze bushings from my local hardware store. I packed it with Green Grease.
What killed mine was someone had serviced it with gear oil and it ate the bushings out of it.
You'll need a blind bushing puller to get the bushings out.
I never found an econoline specific rebuild kit.
Vangoat
Re: Steering box
Post by Vangoat on Mon Jun 05, 2017 3:39 pm
Thank you, I will check into that.
Carl
Number of posts : 127
Re: Steering box
Post by Carl on Mon Jun 05, 2017 7:41 pm
When My adjustment maxed out, it was the lower worm bearing that had broken was the problem
Re: Steering box
    Current date/time is Tue Apr 24, 2018 12:22 pm
