New Battery selection
Zonk 1/75
Number of posts : 80
Registration date : 2016-06-24
Post by Zonk 1/75 on Sat Jun 03, 2017 2:37 pm
My truck is an occasional driver with most time spent parked in the garage.
After an extended absence the battery needed a charge but it drains quickly and I have to jump it often.
I intend to install power window units, door poppers and a sound system.
Considering running a dual battery set-up if necessary?
Was looking at the Optima batteries. Red or Yellow ???
How much Cold Cranking Amps?
Options other than Optima ???
Thanks for any input.....
~Z~
Number of posts : 10025
Re: New Battery selection
Post by vanny on Sat Jun 03, 2017 5:09 pm
Here's a link to a thread that discussed this subject...I just did a search on "battery" using the search tab at the top of the page...
http://vintage-vans.forumotion.com/t49148-battery-suggestions-and-load-requirements-for-our-vans?highlight=battery
Hope this helps! Very Happy
Zonk 1/75
Post by Zonk 1/75 on Sun Jun 04, 2017 5:05 pm
Saw that.......
Found this:
Red vs Yellow
Any reason to limit the CCA or should I get the most available ???
Thanks
Post by vanny on Sun Jun 04, 2017 5:53 pm
From what you were saying about adding a lot of electronics, I would lean towards the yellow top. I can't tell you from experience because I have never had an Optima. Too cheap I guess !!!
    Current date/time is Wed Aug 15, 2018 8:29 am
