Axle flip for my 108
AzDon
AzDon
Number of posts : 395
Axle flip for my 108 Empty Axle flip for my 108
Post by AzDon on Sat May 13, 2017 8:48 pm
I finally got around to processing some pics of my axle flip....
Axle flip for my 108 Azdon_10
Used the top two stock leaves and two additional thinner leaves from a rough country set I got at scrap metal store (I assume they are jeep stuff) Those two leaves had three locator straps that I drilled for bolts and used 3/8 fuel hose as insulators.... Six degree wedges bolted into spring pack and vinyl vibe pads off a roll from speedway motors....
Axle flip for my 108 Azdon_11
On it's wheels after initial mockup......Currently no engine or trans in it....
Axle flip for my 108 Azdon_12
Another shot of the assembled left spring pack...
Axle flip for my 108 Azdon_13
Flip saddle in place with locating nub welded to bottom of axle
Axle flip for my 108 Azdon_14
Tape, white spray paint and a bit of careful measuring determine where the centering nubs belong
Axle flip for my 108 Azdon_15
nubs are simply leftover pieces of the shortened u-bolts
Axle flip for my 108 Azdon_16
More pics later, but here is a pic of everything but the brake drum installed, including new bump stop and air shock......
I reimported your pics at the 640 Pixel setting so the pics wouldn't get cut off...Vanny!
Number of posts : 651
Axle flip for my 108 Empty Re: Axle flip for my 108
Post by samsvan on Sun May 14, 2017 6:35 am
It took me a minute but I figured it out. Your shims looked like they were in backwards but since your axle is on top of the springs....
Nice work Don.
AzDon
AzDon
Post by AzDon on Sun May 14, 2017 3:17 pm
Thanks!..... Hopefully I won't need more degrees because the spring packs will have to come apart to change them, and that requires removal of the u-bolts...
I also notice I need to learn more about posting, as the right third of all my pics are missing....
Post by samsvan on Sun May 14, 2017 3:57 pm
Well that's an easy one! Just change the setting to 640 px width when you're loading your pictures.
AzDon
AzDon
Post by AzDon on Thu May 18, 2017 11:36 am
Update......Put the van back on it's wheels (up on 4 cinder blocks)..... With identical wheels/tires on front/rear, it's 2.75 inches lower in the front, but currently has no engine/trans in it....... I took my dial level underneath to check the caster.......With 6 degree shims, it is showing one degree negative caster......Since I'm going to put taller rear tires on and engine weight will go mostly to the front, I'm thinking 10-12 degree shims is whats needed to end up 2-4 degrees positive..... Fortunate that I left some extra threads on the u-bolts.....
AzDon
AzDon
Post by AzDon on Sun May 28, 2017 2:18 pm
Another update.......12 degrees of shims results in 5 degrees of caster on both sides after I discovered that my cheepo Harbor Freight dial protractor reads differently when turned 180 degrees in place (junk) went back to my Ace hardware protractor that is reliable..... Also new adjustable drag link and re-sealed steering gearbox...... Pictures when I get a chance....
AzDon
AzDon
Post by AzDon on Mon May 29, 2017 8:13 pm
So here is a picture of one of the saddles setting on the pin and waiting for the axle to drop in...
Axle flip for my 108 Axle-saddle-1_1
Here is a pic of the underside of my new bumpstop towers.... My welding looks like crap, so I hide it on the underside...
Axle flip for my 108 Bump-stop-underside_1
Here is what the new bumpstop looks like installed...
Axle flip for my 108 Bump-stop-torqued_1
I had to double-stack 6 degree shims (12 degrees) to end up at 5 degrees caster with the present rake, small back tires and no drivetrain (yet)..... Hopin to end up with at least 2 degrees positive.....I used some 2 inch wide shims I had and extended the inside to keep the indexing nubs on the axle from failing to index..... I drilled the shim stacks and put a dowel pin in each stack paired with the center bolt to keep everything in alignment...
Axle flip for my 108 Sixesstackedandpinned
Here is the left side assembled with the airshock and fitting boot in place....I'll post more pics in my air shock thread
Axle flip for my 108 Fittingtheboot2
AzDon
AzDon
Post by AzDon on Tue Jun 26, 2018 12:27 pm
Thank you for fixing and re-posting my pics, Vanny!...…..
The same topics keep coming up in different places (now on the FB forum) and it's nice to be able just to link back to this batch of pics...
Here is a pic of the van with the correct back tires on it..... I like this stance, but there is still no engine/trans/radiator/battery/doghouse/interior.... so it's likely to be lower once it's loaded up...
Axle flip for my 108 Stance10
[url=https://servimg.com/view/16741936/3][img]
AzDon
AzDon
Post by AzDon on Sat Nov 30, 2019 2:01 pm
Along with my axle flip, I decided to add a front stabilizer bar, which became a bit of a fiasco because stabilizer bars are sold "by application" and not by their measurements, meaning you have to look for something that will fit at the wrecking yard.... For what I wanted to do, a nineties era jeep Cherokee has a bar that's pretty close, but with some additional embellishments that made actual fitment a challenge....Axle flip for my 108 Old_ma10
The bar humps up between the rubber saddles and caused an interference with the master cylinder in it's stock location
Axle flip for my 108 Bar_an10
Here is the right mounting rail I made to hold the bar, the new master cylinder setup, an underpan/scoop and the radiator crossmember, which will be off of the rear of these rails...
Axle flip for my 108 Master10
This is the bellcrank setup I built to relocate the master cylinder inboard at the edge of the tunnel and pointing forward (instead of back)...The bottom of the pedal will pull the heim link rearward....
Axle flip for my 108 Master11
A look at the new master cylinder mount and bellcrank from another angle...
Axle flip for my 108 Master12
Looking inside the 4" square box, you'll see an upper and lower roller bearing holding a 1" shaft stuck through and welded to a nine inch arm that reverses the linkage travel....
[url=https://servimg.com/view/16741936/Axle flip for my 108 Master13[/url]
mocking up the mounting parts
Number of posts : 12212
Post by vanny on Sat Nov 30, 2019 5:25 pm
Way over my head but looks like you have this figured out! Necessity seems to be the mother of invention once again...Nice work Don!
AzDon
AzDon
Post by AzDon on Wed Jan 01, 2020 2:16 pm
I call the new means of operating the master cylinder...…… (drum roll please)….. The heim-link maneuver!
Post by vanny on Fri Jan 03, 2020 6:06 pm
Good one Don! Laughing Razz cheers
    Current date/time is Thu Feb 20, 2020 3:31 pm
