2nd Gen doghouses...
Number of posts : 987
2nd Gen doghouses... Empty 2nd Gen doghouses...
Post by RipVanArkie on Tue May 09, 2017 1:34 pm
Hey guys, been a long time. I'm helping a buddy put a 350 in a 64. We have a 2nd gen doghouse with no radiator at all to work with. First, is the rad mount the only difference in the doghouse? Second, if all I can come up with is the mount for the 6 radiator, is there a radiator that will fit and cool the 350?
Thanks in advance!
Later,
Rip
2013 MidSouth Econoline Meet
1967 Econoline Pickup
1966 Econoline Supervan
Number of posts : 1892
2nd Gen doghouses... Empty Re: 2nd Gen doghouses...
Post by savage on Wed May 10, 2017 5:33 am
Rip, Good to see you back on here,and still working on Earlys You still have any???
The 2nd gen DH is wider at bottom to handle V 8 heads(& getting to plugs) lids a little longer,uses a different E brake lever.
Tom(Millwright 71) used a Alum double pass radiator,with puller fans& shroud worked great.
I'm sure some body else will post what they used also.
Post some pics of your buddy s Van
Number of posts : 547
Post by Russell on Wed May 10, 2017 7:37 am
Look at my page 2 on members vans.
http://vintage-vans.forumotion.com/t52103p25-russell-s-66-sportvan-deluxe
I used a later doghouse and tried to use the stock rad mount but found the rad sat too far from the fan.
2nd Gen doghouses... Rad_en10
Then I cut some aluminum angle to make brackets bolted into the stock mounting holes which set the rad closer to the fan and fit into the doghouse well.
2nd Gen doghouses... Rad310
2nd Gen doghouses... Rad510
    Current date/time is Wed May 22, 2019 8:20 am
