HAVE YOU GUY'S HAD ANY LUCK?
I USED EVAPO-RUST,WORKING SOME
NEED SOME THING STRONGER.
THANK YOU WCW
FORGOT ABOUT THE SEARCH FEATURE ON THIS SITE.
MURATIC ACID SOUND'S GOOD.
CAN YOU USE IT FULL STRENGTH
AND DO YOU HAVE TO WORRY ABOUT
HOW LONG IT'S IN THERE?
THE TANK WILL HAVE TO BE FLIPPED
SEVERAL TIME'S
THANK YOU GUY'S FOR YOUR IN-PUT.
NO ACID WASH.OSPHO AND THE CHAIN TRICK SOUND GOOD.
ALL WASN'T LOST,AT LEAST I KNOW THE GAS GUAGE WORK'S
AFTER PLUGGING IN THE FLOAT.
I RE-STARTED THIS VAN WITH A BURNT OUT SHELL AND EVEN THE FIRST V-8
I PUT IN IT WAS DONE.
I HAD IT FOR SO LONG,I COULDN'T LET IT GO.
GOOD LUCK WITH YOUR'S THEY ALWAY'S NEED SOME THING
THANK YOU WCW
SEVERAL TIME'S
