1965 G 10 bolt rearend
vrod64
Number of posts : 67
Registration date : 2013-07-20
Post by vrod64 on Tue Apr 11, 2017 11:50 am
Broken Axle. Have a 65G that I put a 327 and turbo 350 tranny in. Running slicks in back.
This weekend the rearend finally called it quits.
can anyone tell me which 10 bolt axles are compatable for a stock 65 rearend ?
Thanks
Brian
vrod64
Re: 1965 G 10 bolt rearend
Post by vrod64 on Tue Apr 11, 2017 12:01 pm
More exact question. Summit sells Part# 700115 kit that includes 29.62" axles. Are the 65 van axles 31 1/2 long ?
Is the width of a 65 Van reaend the same as a 65 chevelle, Camero, Nova ect ?
richie61
Number of posts : 429
Post by richie61 on Tue Apr 11, 2017 12:17 pm
Number of posts : 1412
Post by Vantasia on Wed Apr 12, 2017 7:44 am
Donivan can give you the lowdown on axle replacement, maybe just need new higher strength axles, a gear set and new bearings into your existing housing, I think there was a thread with pics on this a few years ago....the new axles have to be modified by grinding the back of the hub or something like that....anyone recall ? easier than swapping the entire rear and axle??
kookykrispy
Number of posts : 1456
Post by kookykrispy on Thu Apr 13, 2017 3:52 am
No it is not the same. The van rear is wider.
I suggest having Moser make new axles. Send them one of yours as a pattern so they get it right.
No1rascal
Number of posts : 279
Registration date : 2013-02-19
Post by No1rascal on Thu Apr 13, 2017 7:22 am
I have a set from a 67 I removed a couple of years back.
If interested send me a PM.
    Current date/time is Tue Jun 19, 2018 8:30 pm
